20 Most Recent
Jenn-Air W30400P Stainless Steel Electric Single Oven Questions & Answers
Display light board faded
Four years ago I had this problem (display goes dim, then goes out altogether) and fixed it per this post:
The circuit board for the display/touch panel is mounted on the back of the display panel itself and connected to the other circuit boards by two multipin connectors. When you remove the display panel (3 screws on top, 4 on the bottom) you will be able to GENTLY detach those connectors. They are low voltage and may be handled safety even when the oven is powered, but I agree that turning off the oven circuit breaker is good practice.
To remove the circuit board, GENTLY release the two black plastic tabs; the solder pads are underneath. I too used a 100 mf capacitor because no local supplier had a 68 mf hi-temp. Observe polarity; the (-) lead goes towards the center of the board (away from the edge connector.) You must use a high-temperature capacitor (105 degrees C, I think) or the problem will recur.
If your oven isn't put together the way mine is, this solution won't work - and I'm sorry to have taken your time.
Display Panel Light
There is a replacement display assembly, i think its around $150-$200. Its pretty easy to change if you are at all mechanically inclined. Good Luck!
Can NOT get cover off
Assume it is the round glass cover.
It is quite robust so use more pressure. Even tal with a piece of wood.
When I start the self
This could a bad temperature sensor or a bad clock.(ERC).
Disconnect the power.
Remove the rear panel.
Unhook the temperature sensor wire and test the temp sensor with a volt/ohm meter set for ohms.
A plus/minus reading of 1100 ohms is good.
If temp sensor reads good replace the ERC(clock).
I did a self clean. now cooling fan runs
many times this is a symptom of a bad oven sensor.its located on the back wall looks like a rod held on by two screws.if your lucky you can remove it into the oven sometimes you need to disconect the wires from the back.otherwise you may have a problem with the main board.try the sensor first.good luck! If you need further help, I’m available over the phone at
https://www.6ya.com/expert/dude_653d05454b389bba
Baking temperature is not accurate.
HI, You will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
Sensor location
The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit.
Jenn -air oven w30400p
Do you mean the service engineer replaced the hinges?
If so call him again and tell him he didn't fix it. The service engineer should come again and fix it for free if there's any justice in this world.
Will not heat.?
Double check the ground and bond wiring. Watch yourself because if the ground wires ARE faulty then you'll be the ground! This could be a very dangerous situation so if in doubt call in a real electrician.
