20 Most Recent
Logitech G15 Keyboard Questions & Answers
Four keys not working on gaming keyboard
i had this prblem before, bought a new one thinking it was broken. Two
days after I got it i found a forum post from someone with this prblem
too and a solution they had was this;
to uninstall all the logitech software from the computer and then
unplug the keyboard from the USB and then uninstalling the keyboard frm
Device Manager. shutdwn, plug the USB back in and then startup again.
I tried it and it worked ! I'd just bought a new one for nothing :s
I'd like the user manual for a logitech G15
Logitech manuals can usually be found here
http://logitech-en-emea.custhelp.com/cgi-bin/logitech_en_emea.cfg/php/enduser/std_adp.php?p_faqid=8040&p_created=1204577470&p_sid=n6I9iVOj&p_accessibility=&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NTksNTkmcF9wcm9kcz0mcF9jYXRzPSZwX3B2PSZwX2N2PSZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PVByZWNpc2lvbiAgVVNC&p_li=&p_topview=1#GamingKeyboards
Spill some water on the keyboard and now when i
if water spilt in any eletronis good first we shut down this thing and pullout battery then it prevent to damage any part. after this we can blow air and make all part and bodry dry . then it can work and prevent from damage
I spilt wine into my G15
LOL, not of course not!
If the keyboard if working then you're ok, but if it doesn't just replace it and stop getting smashed by your computer.
Broken Key
You could look for a key that would physically fit from another keyboard that you'd "slaughter" for that part. The dimensions must fit, and the fastening method. Here's what you'd do to remove the key, and this would also give you some info on the fastening method:
http://theonegreatx.com/2006/12/08/how-to-clean-your-logitech-g15/
Logitech wireless combo mouse keyboard mk220
support through bluetooth
• Check the orientation of the batteries inside the keyboard and mouse, or replace the batteries.
• Is the USB receiver securely plugged into a computer USB port? Try moving the USB receiver to a USB port closer to the keyboard and mouse.
• If the USB receiver is plugged into a USB hub, try plugging it directly into your computer.
• Remove any metal object between the receiver and the keyboard/mouse that may interfere with reception. Try using the mouse on a different surface.
• Restart the computer.
• If these suggestions don't work, download the Reconnection Utility from
http://www.logitech.com/connect_utility.
2/28/2024 3:07:39 PM •
Logitech...
Answered
on Feb 28, 2024
How i can connect my logitech wireless mouse EN60950 to the laptop
Unfortunately, EN 60950 is not a Logitech model number. It indicates that the mouse (or other electronic product) was tested and met the European IEC 60950 standard. Here's a copy of a Logitech EN60950 certificate:
https://www.logitech.com/images/pdf/compliance/AGY-700-018651.001_AGY%20CERT%20CB%20HS%20A00086%20BAER%20CI%20(GGEC)_EUROPE.pdf .
Logitech sells several different wireless mice types. Some connect to Bluetooth only. Some connect with a specific USB wireless transmitter/receiver. The dongle is small enough to fit inside the mouse's battery compartment or stay in a USB port when the laptop is moved. (Older Logitech devices used the Unifying USB wi-fi adapter; new ones use the Bolt adapter.) A few models can be used with both Bluetooth and one of the wireless adapters. These can connect to two or more devices and then a single button switches between devices.
Please try to find the actual model of the mouse to get the correct information for connecting the mouse. Logitech support may be able to sell you the USB dongle if they have the correct one in stock.
I hope this helps.
12/8/2023 11:47:00 PM •
Logitech...
Answered
on Dec 08, 2023
