20 Most Recent
Scunci 52001 Handheld Steam Vacuum Questions & Answers
Heats, but no steam.
The people who manufacture this unit and box it are idots. The manufacturer should that steam can be dangous, and , a user manual should be shipped inside the box. Hey SCUNCI STEAMER dum dums,. Put a printable manual on the site so your customers won,t get hurt by not knowing robert ferriss
Scunci ss1000 handheld steamer
My Scunci MS 1000 heats and builds up steam, but the steam does not release from the spout when the release button is pushed. Plenty of pressure is built up inside (escapes when cap is opened). What is the problem?
Steam will not eject
Same issue with my model. Heated up but would not produce... I called it SED (Scunci Erectile Disfunction) My doctor prescribed him some lube, and it worked! Now days Im happy to say we share a heathy steamy relationship!
Say goodbye to SED forever with the help from lube! All you have to do is open up the unit, locate the circular brass colored button, apply a squirt of lube (wd-40), create a decent amount of pressure and play with the little button until you notice smooth in-out motions. Put the unit back together and BAM you two will be back to a hot and steamy relationship, just like you had when you first met! ;)
No steam
no steam in scunci steamer, it does gets warm but no steam at all. like if it was blocked
Scunci instruction manual
This is the biggest run around! We all should be able to find a manual on the internet for this scunci? I have waisted more time trying to locate the instructions and end up in the same place everytime which is nowhere. Does anyone no where to find it? This is also dangerous and a liability not to have instruction manuals available. We are trying to get it to work and not having any luck. We can't even get the lid off.
Frustrated
Gets hot but will not
Adding a little salt to the water seems to help the steam come stronger. Good Luck!
