I found the following at:
http://www.freshmango.com/support/kb/office-business-programs/windows-xp/xp-numlock-issue-on-login-startup/
This should do the trick...
After some search I discovered that the Numlock control status can be controlled using a registry key which can be found here:
HKEY_USERS \ .DEFAULT \ Control Panel \ Keyboard \ InitialKeyboardIndicators
Simply change the value to either
0 for off or
2 for on.
- Start the Registry Editor
- Go to Start
- Select Run
- Type regedit
- Work through the tree to get to HKEY_USERS \ .DEFAULT \ Control Panel \ Keyboard
- If the key “InitialKeyboardIndicators” already exists then change
its value to the appropriate number, if not, add a new key called
“InitialKeyboardIndicators” with the appropriate value.
- Click OK
- Restart
For the lazier amongst you, simply copy and paste the code below in
to a text file (in notepad), save it as "FixMySoddingNumlock.REG",
close notepad and double click the file:
To make the Numlock OFF by default use:
Windows Registry Editor Version 5.00
[HKEY_USERS\.DEFAULT\Control Panel\Keyboard]
"InitialKeyboardIndicators"="0"
To make the Numlock ON by default use:
"InitialKeyboardIndicators"="2"
