20 Most Recent
Bionaire BCM7207-U Humidifier Questions & Answers
How do I remove the motor housing and clean the
First turnoff the warm air humidifier Bionaire, and from the electrical outlet, you maydisconnect the plug. If there is any container of water from the filtrationsystem and base of the humidifier, you may remove it. By using a towel soakedwith white vinegar, the humidifier's base should be rubbed down. Use warm waterfor washing the base, and use sterilized paper towels or lint-free fabric totumble it dry. The container of water should be emptied. For eliminating thesediment as well as the bulk of grime, you may wash it with warm water. Thewater container should be filled with a cup of white vinegar and warm water.Now, for 20 minutes you may let the treatment sit for the moment. Softly rubthe container with a soft-bristled scrubbing-brush till all scales and depositsof minerals vanish away. The vinegar treatment solution should be left empty.Using warm water, you may completely soak the water container. At this point,you may use sterilized paper towels or lint-free fabric. The filter should bereplaced and on the Bionaire humidifier base, the water container should bereattached. You may now refill and start using your humidifier machine.
You need to follow thisstep-by-step. Hope this will help you.
5/30/2011 7:28:09 AM •
Bionaire...
Answered
on May 30, 2011
How can i change the filter in my bionaire model
on that model that you have you need to turn the unit off , take the water tank off, then the base where the fan is should come off. under the main base the filter will be under that. all you do is take the old filter off and put the new filter on. if you have any other questions please let us know.
3/18/2010 9:57:34 PM •
Bionaire...
Answered
on Mar 18, 2010
Replace humidifier filter
turn the unit off then take the tank off then the base which is the fan portion and the filter fits right there.. if it's a round filter then it slips right on. now if it's the squares they will slip into some slots and usually they will take about 4 if that's the case. if you have any other question please feel free to let me know.
8/29/2009 11:16:38 PM •
Bionaire...
Answered
on Aug 29, 2009
How can i change the filter?
the filter goes under the base. when you take the tank off you should be able to remove the reset of the unit off the base. inside you will see a round part that has your current filter on it. that's where the filter goes. now if there isn't a filter on it already and you have one that's where you put it. if you have any more questions please feel free to ask.
8/29/2009 5:04:30 AM •
Bionaire...
Answered
on Aug 29, 2009
