20 Most Recent
Bionaire Warm Mist BWM0400-U Humidifier Questions & Answers
Humidifier stopped working after cleaning.
It started working again on its own. Not much of a solution!
I think some water must have got into the electronics and then once it dried, the humidifier started to work again.
Christiaan
Need to know how to
I could not find your model number on the Bionaire website, but their customer service phone # is
1-800-253-2764. You could try to contact the company as well. I hope this helps.
How do I reset a
Your component has digital technology which has a tendency to 'lock up'.A reset solution for your problem is to simply unplug it for 5 minutes and plug it back in.That should fix your problem.If it is easier to pull the circuit breaker,that is fine also.Digital components are defined mainly as things which are programmable such as ovens and refrigerators with LCD or LED displays,thermostats,DVR's,answer machines,TV's and much more.Some things which are not exactly programmable but can be reset the same way are video game consoles,modems,battery operated devices,telephones. you have any questions or need more help,just comment here and I will get an autolink to your post and reply ASAP.Greg
I have bionaire cleaning product but no directions on how to use
the cleaning product that you have you need to use once cap full per gallon of water. so if it's 5 gallons you need to use 5 cap fulls. so forth and so forth. that is the easiest way to tell you. and then you let the unit run with the solutions and the water for the hole time until the water runs out. and your unit will be cleaned
