20 Most Recent
Elgin Travel Alarm Clock Questions & Answers
Why does time keep switching to military?
you have it set on 24 hour time instead of 12 hour time
it will change over at midnight to military time as that is when the 24 hour period ( military time ) starts
I am using my mother's Elgin 3400E travel alarm
On my Elgin alarm clock, you just push the nap button and it will add 15 minute increments for a nap. I haven't figured out how to turn it off if I change my mind or wake up earlier than I set it.
I have an elgin anniversary
Usually the problem is a bad batch of batteries. Try taking one from something that is working and see if that is the case.
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
