20 Most Recent Philips 4-Device Big Button Universal Remote Questions & Answers
0answers
17 philips sru3003wm universal
go to www.remotecodelist.com + memorex.comGod bless you
7/15/2013 10:53:43 AM • Philips 4-Device... • Answered on Jul 15, 2013
Code list for mitsubishi
0005 0151 0051 0004 0009 0254 0022 0141 0180
5/4/2012 4:28:24 PM • Philips 4-Device... • Answered on May 04, 2012
Notengo el codigo para mi control remoto philips universal para t
no tengo codigos para programar mi control philip para mi televisor Sony
5/27/2011 5:34:22 AM • Philips 4-Device... • Answered on May 27, 2011
Codigo amw para control remoto universal
11/28/2009 7:25:09 PM • Philips 4-Device... • Answered on Nov 28, 2009
CODE LIST FOR SRU3003WM/17 FOR TOSHIBA TV
these are the codes for toshiba try all to find best one
0517, 0419, 0512, 0613, 0719, 0112, 0506, 0111, 0618, 0627, 0437, 0041, 0094, 0802, 0111, 0313, 0715
7/15/2009 8:37:25 PM • Philips 4-Device... • Answered on Jul 15, 2009
I need the 4 digit codes for Philips Universal
need code for rm 4912 remote control
4/17/2009 1:05:59 AM • Philips 4-Device... • Answered on Apr 17, 2009
Trying to find Codes to use with Magnasonic TV
Try http://www.usasupport.philips.com
or 1-888-philips. It was a big help to me!
3/15/2009 4:55:13 AM • Philips 4-Device... • Answered on Mar 15, 2009
Philips LCD 42PFL3603D/F7 won't stay on until I've held the power button in a few times. The display comes on, then I hear a click and it shuts off. After a few cycles of this it stays on
Remove the cover on the back of the tv. Look for swollen or leaking capacitors. They kinda look like batteries. If they are bulging or leaking then that is your problem. You will have to de-solder the old ones off. Then solder the new capacitors onto the circuit board. Capacitors will cost about 20 dollars and installing them isn't that hard to do. It will fix your tv 99% of the time. So it is worth a try!
2/21/2024 9:36:48 AM • Philips... • Answered on Feb 21, 2024
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM • Philips... • Answered on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay https://www.ebay.ca > ... > Remote Controls Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ... $67.67 · ‎In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay https://www.ebay.ca > ... > Remote Controls PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost. US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com https://www.replacementremotes.com > philips > buy-... PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM • Philips... • Answered on Dec 05, 2023
Philips 4-Device Big Button Universal Remote Logo
28 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
notengo el codigo para mi control remoto
  • Televison & Video
