20 Most Recent
Philips Magnavox MRU1400 Universal remote control Questions & Answers
I used the Library Search procedure to find and
Unfortunately, you won't be able to determine the code from the remote itself. You have two options: either determine the code by manually entering it (from the user's manual), or use the library search each time.
Cant find a remote for
Here is one on eBay for about $17 including shipping.
http://cgi.ebay.com/Original-Magnavox-Universal-Remote-Control-CL034-MINT-/160544923599?pt=LH_DefaultDomain_0&hash=item2561391fcf
How to program this remote?
Here is a link to a user manual this will help guide you through the steps to program the remote
http://www.retrevo.com/support/Philips-MRU1400-Universal-Remotes-manual/id/2782ci960/t/2/
Hope this solution has been helpful?
I need the tv codes to enter in my remote i have a
Please go to below website you can get the codes to programme out remote.
http://www.urc.philips.com/
Please follow the below instruction.
1.Location
2.Select your remote
3.On your left side you will have an option called as REMOTE CONTROL CODE FINDER.
4.Select the device you need to programme and the make of the device you will get the codes.
Thanx
I have the same problem
These are all the codes that ork with your remote on Sanyo TVs:
0506, 0311, 0612, 0002, 0428, 0802, 0412, 0619
MRU1400/17
1. Manually turn on the device (TV, VCR, etc.) to be
controlled.
2. Press and hold the CODE SEARCH button until the
red indicator stays on, then release the CODE
SEARCH button.
3. Press and quickly release the desired mode button
(TV, VCR, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to
300 times) until the device to be controlled changes
channel. The red indicator blinks off with each
button press. If you accidentally overshoot the
code required, press the CHANNEL DOWN button
to backtrack through the library until the device
changes channel. Pressing CHANNEL UP changes
direction to forward again.
5. Press and release MUTE to install the code.
Can this remote work with the Western Digital HD
controlled.
SEARCH button.
Missing codes
0506,0311,0612,0002,0428,0802,0412,0619,Que tengas suerte.
