20 Most Recent
Sony Ericsson Z300a Cellular Phone Questions & Answers
PHONE DROPPED. SCREEN IMAGES SHIMMER AT TIMES,
When the phone dropped, the flex that connect the screen to the main board might have been disconnected partially, if the screen does not look disfigured or have any crack then it is the flex that is causing the screen shimmers at times.
The solution to that is to remove the battery cover, the battery and the sim, then unscrew the phone to dismantle it, after doing that, carefully locate the flex and replace it with a new one or sit it properly.
After doing this, your phone should be in good shape once again.
Take care and good luck
Locked
you may try the following tips.....
Warning: Do not enter any wrong unlock unlock codes on your Sony Ericsson Z300A mobile phones. If you enter over a certain amount of wrong unlock codes on your mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Sony Ericsson Z300A mobile phone without any SIM Card,
2 - Press the left arrow key/button once,
3 - Press the button * twice,
4 - Press the left arrow key/button once,
5 - The message "Personalize with MNC2" will appear,
(or you will have displayed an unlock menu, select the lock you want to unlock)
6 - Enter the Unlock Code.
If your Sony Ericsson Z300A mobile phone does not have a left arrow button/key(e.g. Sony Ericsson W950i) and on a few phones(not all) that have a "JOGDIAL" you must press the "down arrow" key/button instead of the "left arrow" key/button for step 2 & 4. We mean by "Down Arrow" to direct the Jogdial down! In the Sony Ericsson W950i and some other models, the down arrow button/key would be located on the side of the phone.
Phone unlocking
If you want it unlocked from a network, the best way is to go to the network you want to use.
They will unlock your phone for the purchase of a few pounds worth of credit.
How to unlock z300a cell phone
Hi luisacalo,
Unlock codes can be only provided by your service provider , so you need to call your service provider and give your IMEI number , and they will provide your unlock code.
Please leave me comment, if you need further assistance
good luck with your fix.
have a nice day.
A VERY HELPFUL RATING IS APPRECIATED,
Thanks
Regards
Arul
Sony Ericsson Z310a Error code
You must order a battery that is specifically made for your phone. The fact that you have a battery not made specifically for your phone is what the problem is here. Take your phone to your cell phone company nearest store and they'll give you a new battery , most likely for free. Good Luck, hope I helped!
Z300a
Battery is probably junk. Find a friend with the same phone & test the phone before you buy a battery. You migh find a local phone store that will check the phone before you buy a new battery. Otherwise its ebay. Don't spend too much as these were not the best phones even when new.
Good luck, Bob
How do i unlock my phone
Settings
if you go to sony ericson page there you can find a place where they message you all the settings for your network
