20 Most Recent HP ProLiant ML350 G5 Server Questions & Answers
I need Network card (LAN) driver for HP Proliant ML350 5G server.
Go the website of HP, chose for the support and drivers - lookout for drivers and software - enter your product name i.e HP Proliant ML350 5G Server and click on search.You will get the list, select your product. Select the operating system you are using on your server - then choose the driver type - click suitable, from the list of drivers and download it.
4/24/2013 9:54:05 AM • HP ProLiant... • Answered on Apr 24, 2013
How to connected from each computers
Remote desktop or shared drives / folders.
11/30/2012 9:33:15 PM • HP ProLiant... • Answered on Nov 30, 2012
Hp proliant ml350 g5 vga drivers for windows 2000 professional
Download the latest Proliant Support Pack from HP's web site. This will update the drivers for everything on the server at once.
Just go to hp.com and click the link for "Support & Drivers" at the top, then click the radio button to download drivers and enter ML350 into the text box. Select the G5 from the list and then select your OS. The PSP will be near the bottom of the page. The display driver will be close to the top if you just want to update it.
7/12/2009 4:27:59 AM • HP ProLiant... • Answered on Jul 12, 2009
HP SERVER PROBLEM
You should be using a 110 voltage cable if you are in the USA.
6/17/2009 8:09:13 PM • HP ProLiant... • Answered on Jun 17, 2009
How do I fix window 10 to listen audio mp3 cd
NO PC told at all and posted to Proliant server forum that is no PC and as such the OS is not allowed there w10 nor does it have sound chips, at all, its a server running in huge dark, no humans server farm..... so let me guess you posted to wrong forum and never told PC model sure. so windows sounds work in the test in control panel yes ! the, MP3 is complex, it can be from high data rate, source and will not play unless converted . one thing to try is use this free app called Audacity https://www.audacityteam.org/ then play it or convert it or buy a USB sound dac that can decode any sound file on earth or learn to test you PC first windows sounds work then in google type simple MP3 sound test https://file-examples.com/index.php/sample-audio-files/sample-mp3-download/ works good above so your MP3 is no good or wrong bit rate. if fails yours only , buy new DAC USB dongle now it plays them all if windows sounds are dead the sound driver is missing or on a server there is no sound chips oops. buy the DAC dongle. if only 1 MP3 fails out of 100's find a better one or buy a DAC.
4/14/2022 2:22:04 PM • HP ProLiant... • Answered on Apr 14, 2022
I want to install win2003 r2 on HP proliant ml350 g3. But didn't found usb port. Please someone advice me! thx.
Have you connected a CD drive to the machine via one of the SATA ports?
9/15/2015 3:54:40 AM • HP ProLiant... • Answered on Sep 15, 2015
Not display error light and not display on monitor
When you turn it on, does the fan come on? How about the hard drive? There is a serries of tests called POST. I amc4rying to find out what starts up and see where the problem is.
7/8/2015 6:01:30 AM • HP ProLiant... • Answered on Jul 08, 2015
Reset bios putty
You need to be specific about the exact model of server that you're using. Features of the various generations of the HP iLO are accessed in different ways. BE SPECIFIC.
6/13/2015 10:00:54 PM • HP ProLiant... • Answered on Jun 13, 2015
Blinking red light and beep sound coming from the front blade Slot 1.
That drive has failed, is it set up with a RAID configuration? Do you have the Dell monitoring software installed? Is it set up with Hot Plug drives? If so replacing the drive with a new one will start the RAID rebuild. Otherwise one way to turn off the bleep is to reboot and go into the RAID controller configuration
6/12/2014 12:00:16 AM • HP ProLiant... • Answered on Jun 12, 2014
Front blade Slot 1
It Indicating something Faulty, if you have something plugged in, remove, and reconnect, If unable to find, check device manager or event log for details, that should have some info.
12/10/2013 9:27:28 AM • HP ProLiant... • Answered on Dec 10, 2013
Cnnot send pictures on g mail
What happens when you try to attach them
11/10/2013 4:13:11 AM • HP ProLiant... • Answered on Nov 10, 2013
No servers, cant get mail or send mail cp was
If you lost everything then you've obviously reloaded all your software for the server, now you need to load your daily backup tapes onto the server so you can have mail again. you will also need to know all of your DNS's and you MX records if you're running exchange and if you don't know how to do any of it, then my suggestion is to hire a network administrator and it'll cost between $1k - $1.5k by time he's done bringing your system back online.
10/29/2013 3:47:25 AM • HP ProLiant... • Answered on Oct 29, 2013
Open Proliant ML150 G5 tower without the key
Order from HP - Front bezel key 459183-001
12/12/2012 5:18:07 PM • HP ProLiant... • Answered on Dec 12, 2012
My dl 380 does a shutdown when we get a small power outage with ups attached
Test the UPS. The server will stay up as long as there is power and has not overheated, should it be a cool room.
8/28/2012 2:36:53 PM • HP ProLiant... • Answered on Aug 28, 2012
Hp proliant dl 380 server
How big is your UPS backup. Small home / office only last a few hours before the battery drains. Their role is to allow time to save work and shut properly. Large enterprise UPS's last longer, but are dependent on battery bank size and configuration.
8/28/2012 2:34:55 PM • HP ProLiant... • Answered on Aug 28, 2012
DL360 not even going to BIOS
Clear NVRAM by switching ON Maintainance Switch 6.
4/17/2012 6:49:59 AM • HP ProLiant... • Answered on Apr 17, 2012
3answers
I need to know how to turn on a HP X13-04657 LAPTOP, all the lights are on but nothing on the screen.
HP X13-04657, is 2007 PC THOSE this PC has CCFL back lamp strip that is dead.Vista era PC, laptops. are hard to work with now, 17 years old.is this not a HP COMPAQ presario HP X13-04657 (wrong name!) sorry !became HP in 2002. so is HP but manuals are super hard to find now. that x13 is part of the microsoft license code vista. (so is distraction to what it is)the real name of the Laptop is and was Presario CQ61 laptop CQ61 the PC has bottom sticker that shows the real names of PCs.CQ61-219TU is real name of on CQ61, there area many different sub codes, and they are not all the same.CQ61-306AX this had CCFL (cold cathode florecent lamps) that love to fail 3 waysdead, blinks ,dime or yellow = white.was made until 2009 and evolved, to LED backlamps.-410 is CCFLI will answer for CCFL as those just love to fail,but the the test is so easynow the answer for ANY laptop this old. 2007 and older. black screen all the time, and BIOS screens dead, answers only me. here. remove the main battery (large) it simply snaps off the bottom.the power pack is next we run the PC on your power pack AC to DC it must make the screen glow with something, do not use the wrong pack as in mixed up with others.now the lap top seems on, even the fan blows, LED glowpoint a flash lamp at the screen ,dark' room , and of you see any kind of LCD data on the screenthe CCFL lamp below #1 is bad.this is phase 1 testing, as other things can fail too. The keyword below is Mercurythis tells me it is those pesky CCFL glow tubes. 2007 is the year some PC went to LED back lamps. yes I was correct the service manual I did find proves they made both lamp types ccfl-hp07-psnmcz4s4yabbrmds04n13cd-d-0.jpg
4/17/2024 12:37:57 PM • HP Computers &... • Answered on Apr 17, 2024
HP ProLiant ML350 G5 Server Logo
Popular Tags
4 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ProLiant HP
  • ProLiant HP
Most Popular Question
hp proliant ml350 g5 vga drivers windows
  • Computers & Internet
