20 Most Recent Sony Grand WEGA KDF55E2000 55" Projection HDTV Questions & Answers
Sony KDF-55E2000 power led blinks red 3 times....
Are you using an extension cable? If you are, try plugging it directly into the wall. Alternatively, call up the helpline and they may be able to provide more insight into your specific problem.
7/20/2017 9:48:14 AM • Sony Grand WEGA... • Answered on Jul 20, 2017
Sony wega red light blinks 3 times i just replaced
Lamp cover is not properly seat-in. Go back to this part, re-insert and ensure that the safety switch will engage to the cover.
6/23/2016 10:54:00 AM • Sony Grand WEGA... • Answered on Jun 23, 2016
The little trigger wire is broken off the switch under where the lamp goes into the TV. How do I replace this switch and where would I even find one?
you can also eliminated this trigger , it normally goes bad when the lamp is replace , just jump the 2 wires
3/21/2015 5:24:52 AM • Sony Grand WEGA... • Answered on Mar 21, 2015
My doesn not turn on, it blinks 3 times green,
lamp door not closing. most likely it is warped from heat of lamp. this also causes other plastic parts to warp. will need to check unit carefully to see what parts have overheated & melted.
3/4/2015 7:09:19 AM • Sony Grand WEGA... • Answered on Mar 04, 2015
2answers
I have a 2006 Sony KDF-55-E2000, just replaced the lamp and housing and now I have a green stripe at the top and a red stripe at the bottom. Is it worth having this set repaired if I do not have an ex
We had the same problem. Let it be and now the tv won't turn on. If I understand correctly from what I've read it's the optical block and they seem to be just as much as a new tv.
11/6/2014 7:18:40 PM • Sony Grand WEGA... • Answered on Nov 06, 2014
My sony kdf 55e2000 rear projection tv picture and sound go out every couple of minutes, green power light blinks 42 times then the picture and sound come back. Does this religiously over and over aga
Hello, it sounds like the lamp has gone bad, it's gone interminent to the point its like a flasher in your cars blinker system. If you remove it, you might see if it's discolored to a blueish tint instead of a shiny silver mirror finish. On those with the small lamp it can be harder to see. the lamp number is XL-2400.....tks
10/29/2014 3:08:32 AM • Sony Grand WEGA... • Answered on Oct 29, 2014
Hi changed the lamp 2x in the last 2mo v turns on and off when I put old lamp in tv fine
check if the lamp wattage is the same as the old one
10/13/2014 5:30:42 PM • Sony Grand WEGA... • Answered on Oct 13, 2014
My projection tv keeps on
Question shows it is Sony KDF-55E2000 lcd rear projection that has lamp inside as back light source, when this lamp reaches end of its working hours life, it starts such problem.
If lamp has not been replaced in last 2-3 years, then replace it to solve this picture issue, lamp replacement procedure is easy and written in user manual of tv, please buy Sony original lamp from nearest Sony Store for good picture in tv.
Thanks.
7/28/2014 6:34:15 PM • Sony Grand WEGA... • Answered on Jul 28, 2014
Tv doesn't respond to remote except to turn on
Buy a cheap remote for all tv s and program it the model you have you should have a working remote.
6/21/2014 7:35:54 PM • Sony Grand WEGA... • Answered on Jun 21, 2014
Sony wega kdf-55e200
my question is this. our lamps keep blowing in the tv, I need to know if I can replace the fan myself or does it need to go to a technician? if I can do it then where can I find the part? I have been searching the internet and cannot seem to find anything but a lamp replacement!!
1/6/2014 5:32:57 PM • Sony Grand WEGA... • Answered on Jan 06, 2014
The light blinks red continuously on my kdf55e2000
Hello, does it blink in a pattern (example:blink 4 times pause and repeat 4 time blink)? Please let me know. tks
11/8/2013 4:20:37 AM • Sony Grand WEGA... • Answered on Nov 08, 2013
Sony Grand WEGA KDF55E2000 55" Projection HDTV Logo
148 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
own sony kdf 55e2000 when try hook up
  • Televison & Video
