20 Most Recent
Lexmark C534N Printer Questions & Answers
Lexmark C534 . Problem is 920.08 is this the
Here are some steps you can follow to remedy the problem:
1. Turn the printer off, and remove the rear cover. Check the connector JFUSER1 for proper connection to the system card, the cable for pinch points, and the cable or connector for any other damage. Is the cable damaged? If yes, replace the fuser cable. If not,
2. Remove the fuser. Check the DC autoconnects on both the fuser and the printer for damage. Are the connectors damaged? If yes, replace the JFUSER1 cable. If not,
3. Check for the following continuity between the DC autoconnect and FUSER1. Is the continuity present? If yes, go to step 4. If not, replace the DC fuser cable.
4. Replace the fuser. Does the error clear? If yes, problem solved. If not, replace the system card.
945.01 service servo error
945.01 is a transfer roll error service check. Try to turn the printer off, and remove the rear cover. Check the connector JHVPS1 for proper connection to the system card, the cable for pinch points, and the cable or connector for any other damage.If you're not sure on how to do this, please contact our technical support team via phone.
My Lexmark c534n printer keeps jamming.
The fuser rollers might be damaged. Check if the fuser rollers are damaged because if they are they can cause the paper jam, and might need to be replaced.
Black lines on side of page lexmark c534
Please try to print the menu settings page, if you're getting the black lines, replace the photoconductor for the black toner.
If you need further assistance please contact Lexmark Technical Support.
Paper keeps jamming in fuser,
A paper jam as you describe could be caused by the following:
The fuser is defective and causing the jam.
The tray has a problem and it is not picking up the paper properly which causes a timing problem that results in a jam.
A bad sensor is stopping the printer from being able to tell if the right size paper is being fed through the printer.
Try printing from the manual tray to eliminate a problem with the standard paper tray. If it still jams it is very possible that your fuser has an issue and will require replacement. Are there any errors in the error log?
