20 Most Recent Gateway MT6707 Notebook PC Questions & Answers
My gateway laptop mt6707 does not recognize it's DVD player
try external drive.if this work,your dvd drive is bad
4/22/2014 2:01:25 AM • Gateway MT6707... • Answered on Apr 22, 2014
2nd headphone jack on dell inspiron 1420 will not work
The Solutions that will mostly work :
1) Go to sleep mode - wake up ! - tada !! the headphone jack will work again .. I know it sounds crazy.. i have the same model and had the same problem.. usually restarting solves any problem, but this time even a restart did not worked while putting the laptop on standby(sleep) mode and waking it up worked !!
2) If the above does not work, uninstall the sound drivers from device manager - restart the computer - then let windows detect appropriate drivers by itself. Sometimes the Sigmatel drivers(which are provided by dell) do not work as well as windows vista's HD sound drivers. May solve the issue... Do not worry doing this, in the worst scenario you can always download and reinstall the dell drivers from dell support page.
Please update on [email protected] if the problem gets solved..
1/1/2014 10:37:56 AM • Gateway MT6707... • Answered on Jan 01, 2014
Restore dvd
Check the CD/DVD drives status in Device Manager.
  1. Click the Start button. In the Start Search dialog box, type dev, then click Device Manager.
  2. Locate the lDE ATA/ATAPI controllers. Click on the entry to expand the list and make sure there is not a down arrow in front of a device. If a device has a down arrow in front of it, right-click on the device, then click Enable.
  3. Make sure there is not an exclamation mark (yellow splat) on the device. If a device has an exclamation mark, right-click on the device, uninstall and reinstall the driver.
  4. Locate the CD/DVD-ROM drives. Click on the entry to expand the list and make sure there is not a down arrow in front of a drive. If a drive has a down arrow in front of it, right-click on the device, then click Enable.
  5. Make sure there is not an exclamation mark (yellow splat) on the device. If a device has an exclamation mark, right-click on the device, uninstall and reinstall the driver.
  6. Optical drive not detected
  7. Check BIOS setup to verify if drive is detected outside of Windows.
    1. Press the F2 key repeatedly as the computer starts.
    2. Locate the page where drives are displayed. This varies between different motherboards. Please reference your User's Guide for specific model information.
    3. Desktop computers: Refer to the Drive Configuration page (or similarly named page), or the Standard CMOS features page to identify all Optical drives that have been detected. BIOS Setup will present a table which matches drive ports (drive connectors on the motherboard) to drives detected at a given port. Example pages are linked. Reference the Product pages for the specific model. Notebook computers: Refer to the Main page of the BIOS to identify optical drives that have been detected. BIOS setup matches a Drive Port name to a drive detected at that port. Drive Port names (left side) vary per the following examples: > IDE Primary/Master: [HL-DT-ST DVDRAM GSA-T20N-] Left-Bay PATA: PHILLIPS CD-RW/DVD-ROM-(PM) Optical Drive: Optiarc DVD RW AD-7560A -(PM) DVD and CD drive names (right side) will include "CD" or "DVD" in the name.
    4. Inspect and reseat cables. Use proper Electrostatic Discharge procedures.
      1. Turn off computer and unplug power cord.
      2. Disconnect everything except the monitor and keyboard.
      3. Place computer on a stable work area with case cover facing up.
      4. Remove cover.
      5. Find internal drives.
      6. Inspect and reseat any cables to drives not detected. Click here for additional information about drives, motherboard connectors, and drive cables.
        • Check for broken connectors on drive, motherboard, and drive cables.
        • Check for bent or broken pins on drive, motherboard, and drive cables.
        • Check cable orientation.
        • If available, try a different cable. If drive works with new cable, the original cable is probably defective.
12/17/2013 4:26:26 AM • Gateway MT6707... • Answered on Dec 17, 2013
2answers
My speakers work but my headphone jack won't
1) Go to sleep mode - wake up ! - tada !! the headphone jack will work again .. I know it sounds crazy.. i had the same problem.. (ie speakers onboard worked while headphones jack didnt work) usually restarting solves any problem, but this time even a restart did not worked while putting the laptop on standby(sleep) mode and waking it up worked !!
2) If the above does not work, uninstall the sound drivers from device manager - restart the computer - then let windows detect appropriate drivers by itself. Sometimes the Sigmatel drivers(which are provided by manufacturer) do not work well compared to windows vista's HD sound drivers. May solve the issue... Do not worry doing this, in the worst scenario you can always download and reinstall the dell drivers from dell support page.
5/3/2013 4:49:56 AM • Gateway MT6707... • Answered on May 03, 2013
Gateway mt6707 no sounds
Check the Mute button, make sure it is not selected.If it still does not work then install the latest audio driver.You can download the audio and device drivers for your model Gatewaylaptop from this WEB site. Make sure you select your model laptop and thecorrect Windows drivers. Click on this link to download the drivers: -http://driver-pro.com/related/english/hardware-drivers/?a=12221&gclid=COmm19XHtpwCFSMSagodPRuwnQ&hit=1
3/15/2012 4:35:54 AM • Gateway MT6707... • Answered on Mar 15, 2012
Trying to fix an error
Try boot up in safe mode (hit F8 while booting up) and use the system restore to take it back to the day before you erase the files.
1/26/2011 6:48:12 PM • Gateway MT6707... • Answered on Jan 26, 2011
I need a motherboard mt6707
go to company or search chinies site
please yes for vote
1/16/2011 12:00:01 AM • Gateway MT6707... • Answered on Jan 16, 2011
Gateway MT6707 Laptop...Will not boot. I get an
You need to launch the Last know good configuration to get this fixed.
Follow the steps below,
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Last know good configuration".
Step 5: Select that and HIT ENTER.
Step 6: your PC will boot to the windows.
12/19/2010 2:52:44 AM • Gateway MT6707... • Answered on Dec 19, 2010
On startup the comp goes to the windows loading
youll have to re-formatt and re-install OS.You might have an add-on security product if it is a back/white bar this must be disabled,, de-installed first
9/10/2010 8:43:20 PM • Gateway MT6707... • Answered on Sep 10, 2010
I need to clear a
The only way to remove a HDD password is to use a software that can clear that password save on the actual drive, you can use this software from this link for that.
http://www.pwcrack.com/harddisk.shtml
7/12/2010 2:00:55 AM • Gateway MT6707... • Answered on Jul 12, 2010
MT6707 Widescreen Notebook PC (1014360R) PC Notebook: I WANT TO RESTORE A USED GATEWAY MT6707 BACK TO FA...
You can restore the computer back to factory default,to do so, follow the below steps:
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
If the above mentioned steps are not working then you need an RCD to do so. Contact the Gateway support.
5/9/2010 6:05:53 AM • Gateway MT6707... • Answered on May 09, 2010
Mt6707 laptops image looks weird like to much
decrease the contrast of ur laptop screen it will solve it
5/8/2010 5:11:05 AM • Gateway MT6707... • Answered on May 08, 2010
Cannot power on, even when plugin the AC
Hello
This is a power problem.
First remove try charging your laptop with another power cord to see if it works
If it doesnt,remove the battery from the laptop and plug the laptop directly into power if the laptop comes on,then the battery is faulty and you should get a new one
But if it doesnt then the charging port is no longer working and you should get a repairer to help you change the charging port
Thank you for visiting fixya
3/6/2010 1:18:28 PM • Gateway MT6707... • Answered on Mar 06, 2010
My Gateway mt6707 laptop gets dark when I unplug
Hi
Thank you for your query
No this doesnt have anything to do with your battery.
As you can appreicate the your screen needs alot of power so when plugged in there is a continuous source of power so its very bright, however as your battery has only a limited charge, the screen will go dark to conserve
There are 2 ways of changing this
1) Press the fn key + the key with a sun symbol on there this is usually the up arrow key or the right arrow key, but will will vary from manufacturer to manufacturer
2) Click Start> Control Panel>Power options
Inside here you will be able to set what type of power profile you want running on Plug and battery
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again - [email protected]
2/23/2010 5:50:58 PM • Gateway MT6707... • Answered on Feb 23, 2010
Tried to install 2 2gig memory modules (Patriot
Hi
This is because your laptop will only support a maximum of 2gb
I recommend that you take one stick out and see if that works
Please leave feedback/vote if my answer was helpful
2/11/2010 4:27:36 PM • Gateway MT6707... • Answered on Feb 11, 2010
Power
you should check up the ram of the computer and the processor if they are both good ;)
1/17/2010 4:47:25 PM • Gateway MT6707... • Answered on Jan 17, 2010
My Gateway MT6707's screen makes everything negative.
It sounds like the 'High Contrast' Accesabiliy option in windows has been truned on. This is a setting that a person who has visual imparement might use to be able to see the screen and text better.
To turn this off :
  • Click Start->Control Panel
  • Double Click the 'Accessibility Options 'icon
  • Click on the 'display' tab
  • Remove the check mark from 'Use High Contrast'
  • Click OK
Your screen will return to it's not color/size settings.
12/31/2009 7:03:52 AM • Gateway MT6707... • Answered on Dec 31, 2009
Do i have a port for a wireless card bus slot???
There are PCMCIA wireless cards available from several manufacturers.
My favourite manufacturer is Netgear.
10/10/2009 1:07:45 AM • Gateway MT6707... • Answered on Oct 10, 2009
Gateway MT6707 Notebook PC Logo
Popular Tags
54 questions posted
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
M Gateway
  • M Gateway
Most Popular Question
speakers work but headphone jack
  • Computers & Internet
