20 Most Recent
Soundstream XTA720.4 Car Audio Amplifier Questions & Answers
Don't know how to install equalizer. Where does
hi input wiring hooks up to speaker wire outputs on the stereo. in 2008 chrysler has no ignition or accessory outputs. everything is digital, if you use a trunkloc from PAC electronics you will be able to hookup your outputs from the deck into this unit and it will provide you with the RCA, and remote power output needed for your system to operate. the factory deck should have battery and ground at the plug but no acc.
Condensation problem!
All electronics have a recommended operating temperature range. This information can be found in your instruction manual.
Here is a possible remedy to your problem. Condensation forms when air temperature is cold AND there is moisture in the air. Protect your amp from this moist environment, and you're less likely to encounter condensation issues. You did not mention where the amplifier is located, so i will assume that it is in the most common installation area - the trunk. Is your trunk sealing properly? Do you have any standing water in the trunk or water leaking into the trunk? If so, correct this and you should be fine. Otherwise, installing a small fan near the amp can draw moisture away from it and help dry this air out - thus preventing condensation from forming.
Why does it say can't watch video while driving how do I ignore that on my Soundstream VR-769NB
It is a safety feature so you won't won't drive while watching a video or movie while driving.It makes you wonder why they would even make an up front dvd player with a screen if it is illegal ! (And it is !) So now your parents won't be mad at me because I can't give you the solution to make it where you can see it ! I probably just saved your life and someone else's ! Don't be mad or give me a bad review here I just care about human life enough to not help you get into an accident! Good Luck !
