20 Most Recent
Sharp AQUOS LC-45D40U 45 in. LCD Television Questions & Answers
My sharp LCD tv has
Fault at its main digital board.
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
LC-45GD4U
I'm believe the 2 flashing code specifies a problem with the power supply. It is possible that one or more of your supply voltages is out of wack. Have the power supply tested.
Sharp aquos 45 lcd white screen, I can get int the service screen but cant find how to factory reset
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help. Entering service mode option to Sharp TVs are given in detail.
Broken screen
It's ready for the scrap yard. The display will cost as much as a new set.
Replacement screen for 45'' sharp
The only vendor for this would be sharp or a authorized parts dealer. The cost of these LCD panels usually makes the repair senseless. You may get a cost estimate from sharp at 1800-besharp.
I hope this helps,
Skyassoc
Sharp LC-45D40U Has a Intermittent
If tv is under warranty then call Sharp or Store to provide warranty cover because it seems lcd panel has started problem by showing intermittent horizontal line and this problem will increase.
Solution is replacement of lcd panel and its price is approx 80% of new tv so warranty coverage is needed to get it fixed. Check warranty documents of tv and give call to Store or Sharp.
Thanks.
For about 6 months there has been a faint
I've seen a similar looking problem and it is a bad LCD panel. It will show even on a non-used input, and will show through the menu screen and the screen saver, also. Sharp's LCD panels are very expensive,too. Over 4000 at encompassparts.
