20 Most Recent
Acer Aspire 5670 Notebook Questions & Answers
What settings do I need
dont have to change any...connect s-video lead and press fn + the f key that has an icon of monitor on it (little square box)
for instance mine is f2 so I would press fn +f2 (not fn then f2 ,,fn and f2 together)
for most hp the f key is f4...
so you press togethher once and you have signal to tv ..press again you have signal on tv and pc press again and its back to pc only
Why is my Acer Aspire 5670 crashing?
Definitely a hard drive failure, pull the hardrive out if its no longer under warranty(the pc) and you can get hard drive tested kits that allow you to hook up the hard drive to a working pc and test the hard drive for errors, some are so fried they wont even read. The chirping sounds sounds worst case scenario. But it is deffinately a hard drive failure.
Hkgnj
adsgdfnudundjmhfnvlhdnjfndmskdnutpnfjlbfeekl;playingalongthe keyboardmakeyourunitcrashed..dheydflfmnjdmdd,
Sm bus controller?
you need to download the
Intel chipset driver from Acer website
click here
Drivers and Manuals
select notebook then Aspire then 5670
select XP as the Operating System download and install it
hope that is helpful
Acer Aspire 5670 - Keyboard and mouse appear
Hello,You can restore the settings of your computer to a known good date. While in safe mode, do a system restore.Click on Start > Programs > Accessories > System Tools > System RestoreSelect a date when the computer was still working great. Launch it. Let it restart by itself. Once up inside the normal windows, update all device drivers. You can install RadarSync to scan and update all outdated drivers.I hope this helps!David
Computer wont start
hello, try removing the ram and cleaning it. then insert it back. also make sure your CPU fan is working
Aspire 4530 wont boot
The problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
My acer 4150 laptop usb
Before using your USB, scan it for viruses, also run antivirus scan on your entire system. After antivirus scan, clean Windows registry using some reliable software such as Reginout. Now attach the device. Thanks
I have a password on
Just remove the CMOS battery on your motherboard to remove the password. Hope this would help. thanks.
Hi, can not get start up discs to redo my
Your redo disks should be damaged.
Or your memory also could be damaged.
In worst case, try to download the disk again from acer and burn it to a disk and try the new one.
If it is not working yet, you should use a linux live disk to test your memory.
If it is damaged, buy new memory RAM units and change it.
My mic isn't working keep
You must install the correct sound card driver for your OS. And then everything will work just fine.
All of a sudden my computer shut off n then wen
You probably should see if the driver for the mouse and keyboards is properly installed if that's all your having problems with. Go and re download the drivers from the website and see if that doesn't work.
Is it possible to connect
Welcome to Fixya. Yes you can use your Sony Bravia TV. After you connect the Laptop to the Tv press FN + F5 to toggle the display between the laptop and the TV.
Thanks for using Fixya.
