20 Most Recent
Gateway GT5012 PC Desktop Questions & Answers
Cpu overheats
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail. A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
What is the Model of
This actually could vary quite a bit. Most computer manufacturer's will not place a specific model of hard drive into a computer now days, so long as it meets the same standards as the one they originally stock it with.
Your best bet, would be to open the side panel, by removing the small thumbscrews in the back (if they're not thumbscrews, then they're phillips head more than likely) then power down the computer, and disconnect the media cable , and power cable from the hard drive, then look on top of the har drive itself.
IF the hard drive is missing, then only someone that of which has owned one could tell you one of the varying parts that are contained within it.
Even xbox 360's for example, do not use the same brand, or model dvd drive, only the same speed, and connection type.
Good luck,
Dracconus
Hi. I am looking to
You need to purchase a PCI-Express video card.
Your current graphics are built into the motherboard, so you don't need to remove anything, just install the card in the PCI-E 16x slot.
Bear in mind, that you should not try to purchase a power-hungry card, as your PC's power supply is only rated at 300W. Also you will need to make sure that - if the card needs a special power connection plugged directly into it - there exists a lead coming out of your power supply with suitable connector.
Summing up, you'll need to open your case to look for the extra power lead for graphics card, and shop for a card that either accepts the power connector you have, or does not need additional power.
Gt5012 graphics pixilate then computer shuts
Sounds like a graphics card problem. If your using a card, try the onboard graphics by removing the card and test the response. You may need a new card or send it back under warranty.
I have a game that wont install on my computer
Sometimes the drives don't automatically recognize cd's (assuming your using CD). Usually remembers last command which can vary from setup.exe, autorun etc. so if a new CD is inserted with diff. program launch, it can go dumb. You can go to "My computer" and double click on your CD drive (with the game cd inserted) and look for setup.exe or install.exe or autorun. Double-click on one of those files to launch the installer.
Upgrade video card
Any of the cards here are suitabl,e with almost all under $100 and are all PCI Express x 16
Your mobo is not suitable for the PCI X 2.0
Remember the amount of memory on the video card comes from your available ram - so you need to consider this when buying if you dont have much ram.
If you need more help deciding let me know
