20 Most Recent
HP Pavilion a622n (PC108A) PC Desktop Questions & Answers
Hi ... I powered down
power off the computer by removing the power from the rear of the computer then remove the cover of the cpu then also remove the power conector to the hard disk then locate the memory card remove them then wipe them clean with a dry clean cloth then insert the memory into the slot connect the power plug and switch on if the display screen is ok and post bios showing then switch off the computer and connect the power conector of the harddisk
How to reset the CMOS
Turn the computer off....
Open the left side panel.
Find the CMOS battery on the system board.
Take the battery out and short the 2 connections in the round battery casing for 10 seconds.
Reinstall the battery and power up the computer. CMOS/BIOS should be at the default settings afterwards.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
How do I reset the
You will have to gain access to the Motherboard. On it, there will be a round cell battery about the size of a quarter. Pull that for about 15 minutes. Also, when it is pulled, fire up the system. It will beep and state that CMOS is different. OK it and shut the machine back down and put the battery back in. Fire up your PC once more, and ok the time changes. This should take care of resetting BIOS and CMOS
Hello my name is steven
I am assuming that it was working before he gave it to you.
Unplug the pc and open the case and touch the case to ground yourself before trying the next steps. Blow any dust out and away from all the fans, check that all the wires are plugged in tight, check the memory sticks and make sure they are pushed in. Try plugging it in with the cover open but do not touch anything inside with the power on and try it and make sure all the fans are turning. Let me know how this worked. Thanks for using FixYa
The light on the power
try removing the front panel make sure the button isnt clogged with dust or disconected failing that it may well be your power supply internal fuse which can be repaird but a trick job if youare not very good with a soldering iron you may get a replacement one on ebay.
Pavilion a622n restarts during boot process
First step is to get to the Safemode menu. (usually done by pressing F8 during startup but before the Windows XP screen). Select "Disable automatic restart on failure" (Something like that - I can't remember the exact verbage. That way when it crashes you will get the blue screen error and it will stop. Then you can further diagnose what is going on. Post back what it says...
Connection
how are you connecting? what are you useing to connect. Modem, network. are your drivers current for your system? need more infro. in order to help.
Problem getting computer to turn on
Try removing the power lead from the back of pc for atleast 15 minutes and re-connect.
It may be a power supply unit fault that is showing connection but not powering the motherboard.
Open up the side of pc and check the main leads that come from the power supply unit to the motherboard connection are'nt dissloged in any way, or unplug the motherboard connector and place in again this might re-set it.
Removing virtual drive
It depends what program you used to add it in the first place. Open the software and look for settings, or just uninstall it.
What causes a red screen when starting up?
no pc told, Pavilion means zerothat name is is used on desktops and laptops for agesthe HP has diagnostics so run those. HP.com tells how.not told desktop or laptops. just 1 word."Screen"first Pavilion was 1995
What does a HP laptop notebook with model number A6Y530A look like
learn to google mate.
this is no secret,gee millions sold.
A6Y530A
the partsurfer shows true model, and fails
this is the only post here ever asking for reverse code lookups
on models fake, and is not easy in vast cases
I guess you have no such PC, (look like)
so why ask this>? what prompted this quest>? not told
why not ask seller for photos of it if this is a pre sales question , is it>?
google and bing and HP all show that model # is BOGUS
so go back to your sell and ask the we can not guess PCs ever.
HP product ID# is best on the service tag for SURE.
where did you see this number, not told.
or that number is some 20+ year old COMPAQ PC ,lost in the sands of time, and no google hits.
you posted to HP forum, (not real) Hp.com is real
Hp pavilion g series manual
what does not working mean (KBD) dead, or 1 key bad or row. what?
symptoms matter most, for sure in a LAPTOP IS IT
the word Pavilion is on laptops and desktop, dig?
G mean zero , the service tag does not just say "G" sorry.
easy peasy lemon squeezy
HP.com
complex URL no?
go there
tell them your model # or better the service tag code ! .
then magically HP puts you on YOUR service support page
and all manuals and all driver before your eyes. amazing no?
NO told at all
or of a laptop or desktop or what./?
you posted ANON so I can't just read other posts by you to learn what PC this is , no I can not.
there are over 100 PC called G series, and vast years.
some PCs by them G1 to 7 are generations, like
HP Pavilion g6-1029tx Notebook.
if you can find the service tag the product ID # is what matters most
this code includes (real model, version , options and country sold)
see this, older PCs by them had this.
see that , all matters but do not post SN/ or service codes in public.
mine: procuct code (nnnnnnABA#)
https://www.pcdied.com/TAG-jive/tag-elite8540w.JPG
I will guess it is 17" laptop, here is the mess just that 1 sized
once you see this you know that G series means not MUCH>
https://search.brave.com/images?q=hp+G+series++pavilion++17%22+G&source=web
