20 Most Recent
Canon Pixma MP950 All-In-One InkJet Printer Questions & Answers
Photos are pink why
i think ur printer dosent print yellow or blue ink check it buy print nozzle check
Error code 6500
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. but i suggest you to first of all you can try to reset your printer -
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on. If this works you're done, if not try the next step.
1. After confirming that the printer is powered on, open the paper output tray.
2. Open the top cover and wait until the print head moves to the center.
3. Open the inner cover and check that ink tanks are properly seated.
4. Properly seated
5. Press down on each ink tank until a click is heard.
6. Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement .............
Good Luck!!
Printer was working fine yesterday.
Hi blingle2,
Error code "6A00" is an error occurred in the paper "AP Motor" upon self check of the unit.
Affected parts below.
1. Sheet feed unit
2. Purge Unit
3. Logic board Assembly
This kind of symptoms is technical if your not familiar on how to dis-assemble/assemble the unit.
You must isolate first #1 and #2 for malfunction. Take it apart and check/clean the Sheet feed unit and purge unit. After you confirmed that #1 and #2 is in good condition, check the logic board assembly for loose connections before you replaced this board...
Let me know if you are going to fix it yourself and I will send to you the copy of the service manual to guide you on how to assemble and dis-assemble the unit.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
I replaced a color cartridge
Press and hold the STOP/RESET button for at least 5 seconds.
The printer will self-restart and clear the error.
Let me know how it goes.
Color is redish
You have a clogged color print head and needs cleaning or replacement if the old ink hasn't hardened in the jets of the print head.Your printer needs service.
Drivers and Manuals for PIXMA MP950 Windows and MAC OS
Here I will show you where to find drivers and manuals for the Canon
Pixma Mp950 photo all in one printer.
Drivers for this printer are available for Windows
98, windows ME, windows Xp, Windows Vista, windows vista 64bit editions,
windows 7 and windows 7 64bit editions.
On the Mac side drivers are available for Mac OS X
10.2/10.3/10.4/10.5/10.6
A full on screen manual, quick start guide and
other instructions are also available.
To download these drivers and or documentation for
your printer please visit THIS
PAGE
Note that the picture below
reads mp730 but the actual page linked will be for MP950
1. Click on Drivers & downloads
2. Select your OS ( Operating system, windows, mac
etc )
3. All available drivers, documents etc will be
available below.
For some of the documents a PDF reader may be
required to open and read / print them.
To obtain a PDF reader, read this page PDF
Documents. Pdf reader(s)
Thank you for reading and I hope your printer is
up and running again.
-Ekse
Error Code 6500 came on, now power does not come
pls configure your printer maybe not recognize with the pc or maybe the usb of port of the printer did not detect on your pc try to go to bios and check if it is enable the usb . if it is disable just enable .
MP950 printer gets a 6A00 error on power up -
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Error 6A00
Hi
here try this see if do for you.
Solution 1:
Solution 2:
Solution 3:
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
A canon ink tank is not being recognizd.
All ink tanks has a memory chip.With this chip the printer recognize the ink tanks and the ink level.Sometimes this chip failed.Just replace the magenta ink tank.
Ink on back
I take this printer is not under warranty, have your tried rubbing alcohol and cutips, works for me sometimes.
Error U071 or U140
check in bottom of the ink cartidge u must have to remove plastic
strip.then also check u proper fixed ink cartridge in ink tank as
matching color.
re-seating the cartridge may temporarily fix the problem but it will not last. but if even that doesnt give u relief.... then its a hardware failure and wud service is required at this point. contact Hp...
thank you for using Fixya...
have a nice day
Error code 6A00
unistall it and reinstall again it will correct the problem. thanks
