20 Most Recent
Canon Pixma iP6600D InkJet Photo Printer Questions & Answers
Printer offline
HI,tlandstreet 1. Make sure you connect the printer properly to your pc.
2. Check whether the printer is paused
3. On the start menu,go to control panel then printers and faxes
- Is your printer checkmarked as the default printer?
- If not,right click the printer icon
and click set as default printer.
4. Check print jobs for any queued loads.If any,clear the queue manually by moving
to printers and faxes again,
- Right click the printer icon and then click open
- click printer and then cancel all documents
5. Restart the computer and try printing.
- If problem not solved,check out your software
- you may have to install the printer again!
The alarm is on steady and it says printer head not installed install the printer head
On canon printers the head is separate from the ink cartridges. In the manual there should be something there telling you how to replace the head. It is the assembly that the cartridges plug into.
If it is not in correct position due to being jostled when cartridges were installed you will get this error message. So make sure that it is clipped on properly. Or you could have a sensor problem that may be cured by installing and uninstalling the head a few times.
How do I fix error code 6500 on my Canon Pixma?
You should have at the bottom of the print page a error code touch it and it will tell you what that code means and steps to correct it. It's either had a jam or out of ink or paper. If all else fails unplug and restart.
Printer screams when printing
Check the pulleys on the belt which moves the print carriage.
Put a drop of oil on them. Noise should stop
Also please get the service manual for iP6600D from below link it will save you time and money
Canon iP6600D service manual:
http://goo.gl/jov61t
Thanks
Why does my computer not save when I go to print?
Check your default printer It sounds like its set to a virtual printer. You might need to reload some or all drivers for your printer and make it your default printer. (Start menu-Devices and Printers)
How to fix pixma IP6600D error 5B00
Waste ink full - power off printer then press and dont release resume button - press and dont release power - release resume and the press it 2 times (dont release power) - release all buttons - whait while printer is ready then press release button 4 times and then press power button whait about 20 seconds then reboot printer
How can I reset the waste ink absorber
These canon printers are basically a throw away item. You can remove the absorber and clean it thoroughly which is a very messy job and the reset may still not work. You can go online and get a third part reset procedures, of which most do not work. I know this sounds so negative but I have tried many of these and Canon will NOT give out the rest codes.
Printer won't feed paper through
Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the back, by opening the rear door.
Be sure there is no paper or debris hidden anywhere. Open up the rear door and use a flashlight to explore the inside. If you see any paper, have patience in trying to remove it, now gently pull using a side to side motion. If you use a tool for assistance, like a pair of tweezers, or pair of needle nose pliers, put some tape on the jaws of the pliers to help prevent the shredding of the paper.
Another good item to have handy is a can of compressed air. This can be used to blow out any built up dust or fine paper particles that may be embedded inside the printer and the sensors after much use.
Reboot your computer
Try cleaning the paper sensor and rollers
The sensor can be located by opening the front cover where the ink cartridges are. While looking inside just to the right of center manually feed a piece of paper like the printer does automatically. You should see a thin black lever move up and down as you push the paper in and pull it out repeatedly.
This is the paper jam sensor. ANY foreign object in the way of this sensor will cause a three orange light flash indicating a paper jam. Very hard to find without a flashlight. Another good idea would be to blow out the printer using a can of compressed air.
Clean the two Rollers Lightly dampen your lint-free cloth with water or alcohol. Squeeze it out to ensure that it's not too wet. Hold the cloth in one hand and press it lightly against the first roller. With your other hand, gently rotate the roller until you have cleaned it all the way around. Be extremely careful. Do not use too much pressure. You might have to run it through a few times to remove all of the residue
Or Still having Problem Then follow Us For
Canon Printer Support
