20 Most Recent
Lexmark C524 Laser Printer Questions & Answers
In the Model C524 -
1 Is the front access door completely closed?
Yes)Go to step 2.
No) Properly close the door.
2 Turn the printer off, and remove the rear cover.
Check the connector JINT1 (5 V interlock switch cable) for proper connection to the system card, the cable for pinch points, and the cable or connector for any other damage.
Is the cable damaged?
Yes) Replace the front access door 5 V interlock switch.
No) Go to step 3.
3 Turn the printer power on, and check for 5 V dc between JINT1 pin (red wire) and ground.
Is voltage present?
No) Go to step 4.
4 Replace the printhead. Does the error clear?
Yes)Problem solved.
No) Replace the system card.
Lexmark c524 laser printer, i
It could be dust or other foreign object has found its way inside the printer, and is picking up some of your ink. If it is a picture you are trying to print, the program may not be rendering it right on the way to the printer, try using a different program to print.
I keep getting wide pink
The problem is with the fuser, the fuser is bad, you will need to replace the fuser on your printer, in other to fix the problem.
120.1 service fuser error on
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model C524, the manual says you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs around $350, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
There is a problem 120.1
This error normally requires a service call. The fuser is not receiving the right amount of power. But try this. Power the printer off, wait ten seconds, and then power the printer back on. If possible, connect the printer's power cord directly into a wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages. If problem is not resolved, printer needs to be serviced.
The paper has a black mark on the left edge like a
Here are some instructions that you can follow to try to identify and resolve the problem with the black marks.
First click on the following link http://bit.ly/aNzNsl and follow the steps on how to print the Print Quality Pages. Once you have those pages printed Then it will be easy to identify where the problem is coming from. If the problem is more visible in one color than in the others then you might be looking at a problem with either the Photoconductor or the Developer Roller. If the black marks are showing on all the page regardless of color then the problem could be contamination either on the Transfer Belt or in the Photoconductor Units and maybe need to be replaced and/or clean. To clean a contaminated printer you will need to vacuum the inside so that residual toner will not get blown into some other parts of the printer.
Hope it helps.
