20 Most Recent Palm Treo 700w Smartphone Questions & Answers
2answers
New battery on used phone won't charge
The battery might be bad you can go and have someone check the battery at any electronic store with a voltage meter.
12/30/2016 7:04:27 AM • Palm Treo 700w... • Answered on Dec 30, 2016
3answers
Mobile XT not excepting my GPS Receiver
Garmin will work with ANY windows mobile device with built in GPS and or a bluetooth receiver. But you have to have the correct software there are 2 versions both will install but only one will work with your model phone for older model phones use version 4.10 or lower for newer model phones use version 5.0 or higher.
Let windows manage your GPS ports do not try to set it manually. If you have a GPS fix option...go out side where you can get a satellite fix easily...launch your GPS fix program...thenlaunch Garmin. It should connect and you will have to do this only once. I know from experience and I've use this on a T-Mobile Dash with a bluetooh adapter with no issues. I'd try a different receiver preferably any Pharos GPS receiver.
12/16/2016 8:08:36 AM • Palm Treo 700w... • Answered on Dec 16, 2016
3answers
Http://m.google.com/?dc=mgc_oth text to my mobile what
what a big idea.
5/9/2013 1:40:48 PM • Palm Treo 700w... • Answered on May 09, 2013
0answers
Unlock 700p verizon
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
7/27/2012 4:00:29 PM • Palm Treo 700w... • Answered on Jul 27, 2012
4answers
How to unlock my palm treo 700 from verizon
I WOULD LIKE TO KNOW HOW TO UNLOCK MY PALM TREO 700 FROM VERIZON TO ATT
11/4/2011 1:20:12 AM • Palm Treo 700w... • Answered on Nov 04, 2011
0answers
I have Palm Treo 700w for Verizon but I've tried
I will help you..pls mention model number and Serial Number of your phone.
3/7/2011 10:32:19 AM • Palm Treo 700w... • Answered on Mar 07, 2011
I cant connect to the
Please check if you have the correct settings for the mobile network.
to see that go to internet, option and choose the mobile network where there would be a data account and chose to enter the settings there.
If there is no data account, call your service provider and ask for sendng the setting and activating the internet on your number.
Thanks
3/5/2011 6:02:04 PM • Palm Treo 700w... • Answered on Mar 05, 2011
700w lcd replacement now is black screen
Yes, most likely you have missed the proper technique of installing the ribbon strips correctly into the connection block.
I did the same thing and it took me three tries to get it right... I stumbled on this by playing with other ribbon strips on the phone that I could access better and found that there is some sort of “step” or “threshold” inside of the connection block that makes you feel like to have "seated" the ribbon strip at the bottom of the block when in fact you have to push harder to actually push the ribbon into the block fully and make contact with the connectors, and then snap the locking bar down.
It's an easy mistake to make since the connection block and ribbon strip for the screen are hard to get hold of with your fingers... try using some tweezers or small long nose pliers to hold the ribbon and seat it fully.
Now I still am trying to figure out how to unlock and install the touch screen ribbon into the connection block… it’s really small and does not seem to what to unlock to allow for a full installation of the really small ribbon strip and lock it in, so I used a piece of duct tape to hold it in place and it works fine… not my perfect fix on this one, but my ph works…
Robert R.
11/28/2010 2:34:57 PM • Palm Treo 700w... • Answered on Nov 28, 2010
Endlessly connecting
you might need to check the bluetooth device you are connecting to is working and if it is turn it off and try it again, if no luck turn them both of and disconnect any additionals such as battery sim etc for a minute and switch them both on again
7/3/2010 11:41:25 PM • Palm Treo 700w... • Answered on Jul 03, 2010
How to get started a Treo 270 model mobile?
Detail information is given in the manual... from the given link download manual and go through it...
http://www.palm.com/us/support/handbooks/treo/treo700wvzw_ug.pdf
Hope this has helped you... Please rate the answer... Thanks....
6/29/2010 8:50:19 AM • Palm Treo 700w... • Answered on Jun 29, 2010
Cant connect or get wi
Hi, connectivity problem has to do with the network provider all things been equal if there is no problem with your phone.
All you need do is contact Verizon to lodge a complain and you will be told what to do.
Take care
6/23/2010 9:06:57 PM • Palm Treo 700w... • Answered on Jun 23, 2010
Cant get my ringer to work
change the ringer in a mobile repair shop
5/23/2010 5:03:48 PM • Palm Treo 700w... • Answered on May 23, 2010
I have a palm treo 700wx on sprint and I locked
the only way to unlock it is to do a hard reset, but this will delete all the info out of the device, but if you have synced the phone you can sync it back after the reset
4/4/2010 2:55:23 AM • Palm Treo 700w... • Answered on Apr 04, 2010
How can I unlock my Sprint Palm Treo 700w &
it can be unlocked by calling your carrier and they will give you the infomation unlock code as long as the account is current and not delienquent if canceled it will cause some of the features not to work on the device
4/2/2010 10:56:47 PM • Palm Treo 700w... • Answered on Apr 02, 2010
Palm Treo 700w Smartphone Logo
135 questions posted
Popular Products
Top Palm Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
vince
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Treo Palm
  • Treo Palm
Most Popular Question
http m google com dc mgc oth text
  • Computers & Internet
