20 Most Recent Xerox WorkCentre XL2130f Laser Printer Questions & Answers
Automatic feed does not work
The wheels that are supposed to grab the paper might be dirty or broken, the reason can also be that the sensor that should see the paper doesnt work for some reason.
11/14/2011 6:35:22 PM • Xerox WorkCentre... • Answered on Nov 14, 2011
0answers
We have an error code
I would suggest you replace this machine because the problem is very common with this machine. Unfortunately, there is no information on the code, just as you already know. The only error code info for this machine is error that starts with X, but there is non for L errors.
But before you conclude on replacing the machine, this is what you will have to consider.
Ascertain the cost of fixing this machine, then compare it the cost of getting another one. The price difference would determine whether it is worth repairing or not. I hope you understand what I mean.
Regards.
7/12/2011 3:15:05 PM • Xerox WorkCentre... • Answered on Jul 12, 2011
0answers
I have a xerox workcentre XL2130. It had a bad
YOU STILL HAVE A PROBLEM IN THE PAPER PATH...
DOWNLOAD THE USER MANUAL
Clearing the Paper Path
- E-1, E-2, E-3, E-4, E-5
When a paper misfeed occurs the red misfeed indicator flashes
on the WorkCentre diagram, and an E status code will flash in
the Display Window. Paper misfeeds may occur in the areas
shown below. Follow the steps below to locate and clear the
misfeed.
Note: Ensure that the alternate paper tray is lowered
(XL2140df only).
Caution: Do not touch the shiny drum cartridge surface.
Scratches or smudges will result in poor copy quality.
Do not remove paper through the bypass. Unfused toner may
adhere in the area, resulting in smudged copies.
E-1
Steps 1-2 for XL2140df only
1. Lower the right Side Tray 2 Access Door.
2. Remove the misfed paper.
3. Close the Access Door.
If paper cannot be removed, open drawer (2) clear misfed paper.
4. Close the Side Cover.
E-2
1. Press the Release Latch to open the Side Cover.
Exit Area
Paper Feed Area
Fuser Area
Side Cover
35
- E-1, E-2, E-3, E-4, E-5 (continued)
Caution: Do not touch the shiny Drum Cartridge surface.
2. Carefully remove the misfed paper in the direction shown.
If paper cannot be reached, open the paper trays and remove
misfed paper.
E-3
Fuser Area
Warning: The fuser area is hot. Take care when removing
paper from the fuser area.
Note: Ensure that the Alternate Paper Tray is lowered
(XL2140df only).
1. Press the Release Lever to open the Side Cover.
2. Pull down on the fuser lever.
• This will release pressure on the paper.
Caution: Do not pull paper up through the fusing unit. Unfused toner
may adhere in the area, resulting in smudged copies.
3. Remove the sheet of paper in the direction shown.
E-4 and E-5 (2-sided Reverse Copy XL2140df only)
Exit Area
1. Pull down on the fuser lever.
2. Gently pull the paper out through the exit area.
36
3. If not accessible, turn the knob in the direction of the arrow
to move the paper to the exit area.
4. Gently pull the paper out through the exit area. I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
2/12/2011 7:58:57 AM • Xerox WorkCentre... • Answered on Feb 12, 2011
I have purchased a remanuf
Most likely the "remanufactured" cartridge does not have the counter reset flag in the proper position or is missing completely. Just reset the counter via the service mode by pressing these keys in sequence and as quickly as possible (within 4 seconds).
Press Clear, then exposure mode (far left key) the clear then exposure mode again. So in short form C, Far Left, C, Far Left. If done properly the display will go blank. Now key in 24 as if you wanted to make 24 copies. Now press the print button. Now enter 7 then press print again. You should now see flashing 000.
Press C a few times to exit and the drum light/J2 should now be gone.
Good Luck and Thank You for using Fixya.
WheatlandServices
1/31/2011 8:47:45 PM • Xerox WorkCentre... • Answered on Jan 31, 2011
0answers
How to remove glass on dell 948
You have to lift the document feeder up and out of the slots in back.
I would also recommend removing the screws from the back cover and taking it off. Then take the two front screws off on the top holding both the ledt and right top covers. Remove those covers, and also remove the one screw holding on the plastic strip along the back of the glass.
Then remove the glass. Be careful cleaning the scan head. That lamp is very fragile.
12/31/2009 12:11:34 AM • Xerox WorkCentre... • Answered on Dec 31, 2009
Diagram of how to remove a exploded toner
Compressed air and a toner vac. You might need to remove the platen glass and clean up under there as well.
8/4/2009 5:13:36 AM • Xerox WorkCentre... • Answered on Aug 04, 2009
L 6 code flashing
That is a laser fault. Normally the motor that turns the mirrors in the laser assembly is failing.
You can also try this. take the back off the machine, there is a ribbon cable attached to the main board that I have seen unplugging and re connecting resolves an L6.
about the best price I have seen on that laser is about $300.
Google a business called "the parts drop". You can look up the part and price there. Honestly, that is one heck of a job replacing that laser. You pretty much have to split the machine in half to replace it.
3/2/2009 8:38:33 PM • Xerox WorkCentre... • Answered on Mar 02, 2009
Shut down at 18,000 pages, J2 code
that is the exact life of a drum for that machine.
2/22/2009 1:46:24 AM • Xerox WorkCentre... • Answered on Feb 22, 2009
Workcentre XL2130f does not ready itslef sometimes
Normally when that happens the machine need a general cleaning. Also take the toner cartridge and shake it side to side to be sure there is enough ink where the density sensor is.
There is a light on the machine that will start flashing when the drum has about 500 pages left on it.
What you most likely have to do is take the toner cart and drum out, clean in that area well, Take a flashlamp and cloth dampened with some alcohol and clean any sensors , lamps you see. Also look to the left, you will see an opening about 1/4 of an inch high and 6 inches wide, That is your laser window. You want to take. most likely a Q-tip and clean that glasss inside that slot.
On thre right side door there also is a tranasfer wire, it is in an opening in a metal bracket that will need cleaned. Be cautious since it is a very thin wire. Dampen a q - tip with alcohol and gently wipe back and forth to clean that wire.
Then remove the screws around the glass, lift out the glass and clean the underside of the glass , lamp and mirrors.
The XD2130 is really a good machine, if you don't remember repalcing a drum on it, then you must not have a very high volume on it, I would even pay someone to clean it for you if you like.
Xerox doesn't service it any longer, but parts and reputable people still service those on a daily basis. Its a good machine,
1/13/2009 8:49:30 PM • Xerox WorkCentre... • Answered on Jan 13, 2009
ERROR MSG CH
A CH code means the toner cartridge is not being sensed.
Could just be not seated properly. Open the front and remove and reseat the toner cartridge.
It may be empty also.
8/25/2008 12:39:19 AM • Xerox WorkCentre... • Answered on Aug 25, 2008
Xerox work centre xl2130f developer
It goes in with the toner. The developer and toner mix in the cartridge. Empty the old out and put it in with the toner.
Good luck.
2/7/2008 9:02:04 PM • Xerox WorkCentre... • Answered on Feb 07, 2008
Xerox workcentre 3345 paper jam in tray1
If you've modified one of the trays and still encounter the same error, it's worth checking if there are any obstructions in the paper path or if the default paper type and color settings need adjustment. Remove Jammed Paper From Tray 1: First, remove any paper from the Bypass Tray. Grasp both sides of the Bypass Tray and pull it straight out of the printer. Next, pull out Tray 1 until it stops. To remove the tray, lift the front of it slightly, then pull it out of the printer. Check for any jammed paper and remove it. Also, make sure there's no crumpled paper left in the tray or jammed inside the printer. If you have Tray 2 (optional), check it as well. Insert Tray 1 back into the printer and push it all the way in. Fully insert the Bypass Tray as well. Confirm the paper settings if prompted. Try your job again. Power the Printer Off then On: Press the Power/Wake button on the printer control panel. Choose "Power Off" to turn off the printer. Wait for a few seconds, then press the Power/Wake button again to turn it back on. Retry your print job. Replace the Paper Feed Roller (if needed): If the issue persists, consider replacing the paper feed roller. Refer to your printer's documentation for instructions on how to do this. If the problem continues, contact Xerox support.
4/20/2024 9:16:59 PM • Xerox Office... • Answered on Apr 20, 2024
Xerox 6204. What is solution to error code 123-315 please?
Question edited for clarity. I found this 123-315 UI Panel Communication Error N 2.2. There is help in the first link but you need to register https://www.google.com/search?q=xerox+6204+error+123-315 ..
3/24/2024 8:05:00 PM • Xerox Office... • Answered on Mar 24, 2024
Error 40b7853c 3T 915 on Xerox Phaser 3300mfp what does it mean?
That means there is no communication. There is a system error that is probably a fatal error. You could try updating the firmware.
2/11/2024 12:50:33 PM • Xerox Office... • Answered on Feb 11, 2024
Xerox WorkCentre XL2130f Laser Printer Logo
21 questions posted
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Xerox Office Equipment & Supplies
Most Popular Question
l 6 code flashing
  • Office Equipment & Supplies
