20 Most Recent
Zoom (5590-00-03) Wireless Router (G66115) Questions & Answers
Help would be nice.
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
3/18/2012 5:49:40 AM •
Zoom...
Answered
on Mar 18, 2012
Need to get wpa encryption
The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key.
The Passphrase generates the WEP or WPA or WPA2 encryption keyand this is in the router's wireless settings.
To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router.
2/27/2011 10:41:26 AM •
Zoom...
Answered
on Feb 27, 2011
The wifi data which can connect but there no ping
Routers have the ability to turn off return ping.
This is great for security because it is harder to tell if a device is at a certain address simply by pinging it.
Simply log into your router and go into the advanced settings. There should be an option to enable pinging if you do want it to be enabled.
2/23/2011 8:23:50 AM •
Zoom...
Answered
on Feb 23, 2011
I can't figure out how
In order to get your router back to the original settings, you must push
in the reset button (usually on the back of the router) for somewhere
between 10 and 30 seconds depending on the router. You may need a pin or
something small to push in the button, because it can be recessed. Once
you have reset the router, the username and password will be changed to
the defaults, admin and password, respectively. One thing you must
remember is that resetting the router will change all of the router
settings back to the factory settings. This means you will lose all of
the changes you made since you got the router. Make sure to write down
any things you've changed, so you can change them back after the reset.
Also, I recommend updating to the latest firmware after the reset.
If you need more help post back!
Thumbs and testimonial are welcome!
1/19/2011 12:21:23 PM •
Zoom...
Answered
on Jan 19, 2011
Need to find out my
The password is the encryption key in your wireless router,
without this key the wireless router won't allow the laptop or PS3 to connect to this
wireless router.
The WEP, WPA, WPA2 encryption key is in your router's wireless
settings. Log into your router and got to the wireless settings, you will need
to get the SSID and the encryption key. Then go to your PS3 or computer/laptop's
wireless card and configure it with the router's SSID and encryption key, so it
will then connect to the wireless router and the Internet.
To secure your wireless network from
unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security.
12/26/2010 7:18:45 AM •
Zoom...
Answered
on Dec 26, 2010
I forgot my password log in
This device does not comeup with password recovery option.
Only thing possible is to reset the password
10/31/2010 3:51:16 AM •
Zoom...
Answered
on Oct 31, 2010
How can I put a password on the wireless router so
1. you will need to log into the router to setup the wifi security.
Your user manual will have specific instruction.
link here
http://www.retrevo.com/samples/Zoom-manuals.html#Wireless%20Router
you didn't specify a model number.
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model router
10/25/2010 2:54:56 AM •
Zoom...
Answered
on Oct 25, 2010
Have purcased I pod touch
you need you SSID and your wep/wpa key to connect to any wireless device. Use the same information from your laptop conenctions and it should work.
9/1/2010 10:55:12 AM •
Zoom...
Answered
on Sep 01, 2010
Forgot the password... need to
If you're talking about the password to get in the router setup page that you have forgotten, the only way to reset it is to press and hold the reset button of the router for 10 seconds while power is ON and it will be back to its default settings with default username and password.
8/21/2010 4:56:15 PM •
Zoom...
Answered
on Aug 21, 2010
Hi i ahve a zoom
u have to configure it to connect to the internet once again through ur default gateway and to look for that open a command line in windows and type ipconfig and u should see ur default gateway. then type that in ur browser and VOILA!
8/11/2010 10:01:37 PM •
Zoom...
Answered
on Aug 11, 2010
Connect to networks except on home network
Make sure in your router all settings are fine.
Also change wireless channel type in wifi router also Disable WEP security in your router for checking purpose.
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.1.1 or
http://192.168.0.1 or
http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router. Then click on wireless settings then change channel type to 11 also disable WEP or WPA or WAP security in wireless security if it is enable.
Then save settings and restart router.
Then check.
Let me know if you need further assistance. Thanks for using FixYa.
7/27/2010 6:26:04 PM •
Zoom...
Answered
on Jul 27, 2010
How do you set a password on the x6 zoom wireless
Connect to the router through your browser. (Internet Explorer/Firefox/Opera) Open your browser and where you would type in
www.google.com type 192.168.1.1, login, if it asks for a user/pass there is a couple different ways to do it if its all still default settings. Some routers are different when it comes to login defaults so here are some suggestions.
1)
Login: Admin
Leave password blank and try logging in that way
2)
Login: Admin
Pass: Admin
3) Motorola users
Login: Admin
Pass: Motorola
If this doesn't help my aim is candidate4death. Throw me a IM.
7/26/2010 3:00:59 PM •
Zoom...
Answered
on Jul 26, 2010
Zoom 3g 4501 router gets no internet connection.
Check your internet settings in IE & Firefox. Make sure there isn't anything checked off that would prevent you from browsing. Also check your Internet & Network connections in Control Panel. I had this problem once myself with Firefox and I actually had to System Restore back a week because something I downloaded had a Trojan and infected my browsers. AIM me @ candidate4death if you need further help. Thanks!
7/26/2010 2:56:04 PM •
Zoom...
Answered
on Jul 26, 2010
