20 Most Recent
Zoom Wireless-G 4410 (44100000) 802.11g/b Questions & Answers
Is the 4410 compatible with Windows 7
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is
for other versions of operating system. I am also using windows 7 like
you so don't you worry, You can still use your old installer/driver from
other versions of operating systems. Just remember that before
installing any program in a windows 7 Operating System Computer, Use
"troubleshoot compatibility". Right Click the Icon of your program
installer/application first, then choose "troubleshoot compatibility". This will
allow you to choose on what type operating system your program will run.
Just reply back if it still doesn't work.:D rate and vote for me:))
System crashes and re-starts
N oyou not need to purchase new 1 /
But just make sure that your usb devcie is not conflicting with any other driver or device.
For that uninstall your zoom adapter usb driver then reisnstall.
Also some usb adapter give some memory space so if you have memory space on your zoom adapter then scan it for viruses or format it.
Then it works fine.
Let me know if you need more assistanse.
Thanks.
My computer keeps restarting when i have my wifi..
It looks like your computer is overheating. I am assuming that you place your laptop on a table and it works fine for 20 minutes. After it gets hot, it shuts down. If it did not shut down and turn off, it would burn up and die. The fans and vents on your laptop are on the bottom of your computer. Place your computer on something that will allow air to circulate and cool your computer. There are stands that you can buy from 20 to 50 dollars that you can place your laptop on that will alleviate this problem. Let me know if this solves your problem. Paul Marchand
[email protected]
Computer restarts every time
you better check your restart switch... that might be pressed on....if so unscrew your computer and the cable that passes thorugh the reset button take that out...( you can unplugged) ... for that, you can follow the diagram inside. of the computer...
perhaps it may help your problem....
and to format c drive. you have to install operating system cd and can follow the instructions if your computer's reset button works first...
I have the zoom wireless g router adapter
*Check the advance settings of the router:
Turn the MAC filtering off
Disable the wifi-protected setup
*For the computer settings:
Disable the IEEE of the wireless adapter.
- Reconnect to the network again.
Note: Just make sure that the driver and adapter are installed properly.
Re your email
P2p stands for file sharign programs. direct downloads are just forect donloads from the internet without file share programs
USB wireless adaptor
I'm working on another thread with the same product. Make sure you unistall all zoom software from your computer. Restart your computer. Plug the wireless adaptor in and let it find the drivers you need. It may need the CD that came with the adaptor but don't install any thing from the CD but the drivers.
Use the WEP id and password system from Windows networking.
Removing the utility
Do this....
Uninstall the whole program. You should see an icon next to the zoom adaptor in your programs when you press the start button to uninstall it.
If you don't you will have to go into the control panel. Select add/remove programs. Look for it in the list and unistall it that way.
Plug the wireless adaptor in your computer and let the computer scan for the drivers. It may need the CD that came with the adapter but don't load anything else off of the CD.
Zoom adapter
Do you have a wireless router connected to your network?
Speed
ok, thats very very slow. no wonder your having problems.
You will need call your internet provider to sort this, there maybe a problem at the exchange. mine comes back as 6.3mb down, anything under 1mb is deemed as un acceptable
