20 Most Recent
Hitachi DZ-GX3200A DVD Camcorder Questions & Answers
I put in a new
sometimes there is nothing wrong with the camera, it is the disks themselves that can cause that error. I always use memorex or verbatim for disks, and there has never been an issue with them. some of the lower priced disk, like sandisk and lg disks sometimes have an encoding error in manufacture that causes the drives to not read them.
12/16/2010 9:11:15 PM •
Hitachi...
Answered
on Dec 16, 2010
I have a hitachi DZ-HS903A
Ebay is your best bet or of course the manufacturers web site will usually have links for these things.
static.highspeedbackbone.net/pdf/Hitachi_DZ-HS903A_Manual.pdf
http://shop.ebay.com/i.html?_kw=AC&_kw=DZ&_kw=ACS3&_kw=DC
Above is a link for a charger, i think you would have to buy a new one in it's entirety?
No I doubt that it will be the fact that the "
video was not finalized" (sic) It is more likely that the HDD has faulted. It may be able to be rescued, by reformatting? It is more likely the HDD has failed?
You will in this case have to take the unit into an authorised service center and ask for a "Quote' before commencing any repairs. This way you can decides to repair or replace.
One can replace a HDD oneself, if technically capable. If this is what you wish to do, there are tutorials on the net to assist.
8/4/2010 7:53:54 AM •
Hitachi...
Answered
on Aug 04, 2010
How to download film to laptop
have a look in http://free-download-films.com/
maybe you will get a satisfied answer.
hope it can help you more or less!
7/28/2010 1:51:53 AM •
Hitachi...
Answered
on Jul 28, 2010
How do I upload my raw-video from my Hitachi BX35A mini DVD-RW camcorder to my pc for editing?
Hi
I think I had a similar problem with my new Panasonic DVD camcorder. Even though I had finalised the RAM disc the PC could not read the disc but could see it. I tried drag & drop into a new folder on my PC. I then renamed the video files by changing the ending to .VOB.
I could then open & play these files in Power DVD. Using software downloaded from the internet I converted the VOB files into AVI and could then use PINNACLE to edit them into a holiday movie/DVD. Some software will enable editing/reading of VOB fileswithout converting to AVI but as I am familiar with PINNACLE I just stick with what I know! Bit laborious but it worked for me.
I still prefer my mini dv camcorder - firewire works perfectly & direct into PINNACLE software for editring..
Hope it works for you
Dave
12/23/2009 11:22:29 PM •
Hitachi...
Answered
on Dec 23, 2009
"invalid MS -DOS function"
What OS are you using? are you using XCOPY or XCOPY32 to copy the contents of the disk over? Try to use an ISO Image Creator like MagicISO(Shareware), or the Nero Application Suite(Not Free) or WinImage(Freeware).
7/16/2009 5:09:49 AM •
Hitachi...
Answered
on Jul 16, 2009
Disc error
if you get a disc error, DO NOT TRY TO REPAIR the data.
When you get a disc error, turn the camera off, turn the camera back on. When prompted to repair the data, select NO.
The camera should prompt you to Format the disk, select no.
you should go back to a normal camera screen, at this point push the FINALIZE button on the outside of the camera to finalize the disc.
This is your only option to save the data.
Never try to repair the bad data, it never works.
I have done this on two occasions, and it worked both times.
3/4/2009 2:56:58 AM •
Hitachi...
Answered
on Mar 04, 2009
Help ejecting dvd
I had the same problem and tried for ages (even tried forcing the door open thinking I could just tape it shut) without luck.
Then my very clever wonderful husband had a go (I know i'm crawling and yes my knees hurt).
Any way to the relevant bit. If you hold the eject button down and at the same time slide a knife or similar object round the edge of the door where the screw is near where it says photo/select you'll find that the door opens as this is an override mechanism.
3/3/2009 2:23:12 PM •
Hitachi...
Answered
on Mar 03, 2009
Hitachi bx35a
Well you might neeed to rplace it. Just rememver when you get the new one to not drop it becase devises like this are sensitave.
1/10/2009 5:29:07 AM •
Hitachi...
Answered
on Jan 10, 2009
Hitatchi bx35a... after recording no data
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
12/12/2008 6:10:18 AM •
Hitachi...
Answered
on Dec 12, 2008
Dvd camcorder
I have actually seen a lot of problems with this model camera and this happening. Your only chances are sending the dvd into an expert to try and do it. As there is no way to recover the data yourself when this error occurs. I would get a different camera. This is another one of the reasons I do not recommend DVD camcorders. You are much better off with miniDV.
Thanks,
Lee
6/30/2008 11:04:58 PM •
Hitachi...
Answered
on Jun 30, 2008
