20 Most Recent
Hitachi DZ-MV550 DVD Camcorder Questions & Answers
What is the file format of the videos on the DVD-R
Hey! As far as I know, vob is the format of videos on the DVD-R discs.
I think you need a conversion tool and this
DVD Converter Ultimate will be of help to you. This DVD Converter can help you convert various video format (including vob format )to any video format, rip dvds to video and burn video to dvds for playing on DVD players. You can have a free try of it. Hope that helps.
Hitachi dz-mv550a dvd door jammed
when you get to the small rectangle hole use a small flat screw driver. you'll see the lever on the door side. put you're screw driver to the front and pry it backwards and it will unlatch.just pressing on it won't do anything.
Eject the tape on Hitachi VT-FX695. It stays on for about 45 seconds and will not eject and then powers off.
hi,
the door mechanism is may be gripped because of a small kick...
did you try to open the door with a full charged battery and with the wall plug connected too ? help it with a toothpick or the corner of a credit card...
if this doesn't work, it may be the motor that is dead, do you ear any little noise when asking the ejection ? if yes, it is the mechanic, if not, it is the motor or the motor driver that is dead.
cheers,
mich
Error Code 2881 will not work
i put mine in the shop it is the laser and it cost $219.00 for the part because it comes in an assemlby piece it depends on how much they charge for labor. I choose not to fix due to high cost of it all it is in a bag besid emy computer
Error has occurred. error code
Error
0280 - It looks the DVD had bad spots that
could not be read.And... are you check your
User Manual?
Once clicked, you need to put the verification numbers on the screen and save to your dekstop.I just find thia comments that I quote:
After getting frustrated trying to get any info from
Hitachi manuals and support, I just decided to try to extract the data
directly from the dvd (fujitsu dvd-r disk). Since my DVD was not
finalized I could not copy the files directly using Windows Explorer, so
I tested several applications and here it's what worked for me: I
downloaded isobuster (www.isobuster.com), and I was able to view the
tracks on the dvd, then I used the "Extract" option to create an image
directly from the faulty dvd and it created a couple of files with the
extension .ibq. I checked these ibq files and two of them were huge, so I
assumed those were my video data. I renamed these files from *.ibq to
*.vob(isobuster has options to extract these "image files", but you need
to register it first...), anyways I tried to open these new vob files
with PowerDVD and they PLAYED JUST FINE :)! Finally I just used a DVD
editor to load the new .vob files and I burnt a new DVD.If this wont work, try with Hitachi
Technical Support; they offered to the Hitachi DVDCAM customers via Email on this website: support.hitachi.ca/EmailHope helps.
I am trying to upload
drivers can be found here:
http://dvdcam-pc.support.hitachi.ca/en/download/dl.asp
About halfway down the page look for "USB DZMV5.exe
Gravar Vdr-M50 windows7
Maybe, It doesn't work because the driver you installed is for other
versions of operating system. I am also using windows 7 like you so
don't you worry, You can still use your old installer/driver from other
versions of operating systems. Just remember that before installing any
program in a windows 7 Operating System Computer, Use "troubleshoot
compatibility". Right Click the Icon of your program installer first,
then choose "troubleshoot compatibility". This will allow you to choose
on what type operating system your program will run. Just reply back if
it still doesn't work.:D
