20 Most Recent
Jenn-Air JMV8208A Microwave Oven Questions & Answers
Microwave appears dead, kid tried
There is a ceramic fuse located on the inside of the microwave oven, unplug unit remove cover "2 to 6 screws" allow 30 seconds for the high voltage to discharge, on the right side you will see a keyboard, to the left of that you should notice a silver capacitor rectangular in shape, fuse will be near by, "whitebody with silver ends" remove and take it to a Radio Shack Store or an Appliance repairman to properly size up. When you assemble, plug unit in, "remember there are dangerous high voltages if left exposed" so make sure the top is on before using.
5/26/2011 1:31:59 PM •
Jenn-Air...
Answered
on May 26, 2011
Louder and not heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic
Microwave Oven TroubleshootingTips
heatman101'['[//'[
3/27/2011 6:19:24 PM •
Jenn-Air...
Answered
on Mar 27, 2011
MyJMV8208 Jenn-Air microwave will not heat. How do
take the unit down
open the top cover all the way out
some units have manual inside that tell you how to fix it but you will see all cutoffswitch
90% it is the
Magnetron and by the way the unit have 4000v so be sure you know how to do it or ground the capacitor first!!
Magnetron
coast only 80-120$
1/19/2011 1:00:52 AM •
Jenn-Air...
Answered
on Jan 19, 2011
The microwave all of
Here
Microwave Oven....
Basic Microwave
Oven
Troubleshooting Tips
heatman101
1/15/2011 2:36:59 PM •
Jenn-Air...
Answered
on Jan 15, 2011
No power, it is like
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....Microwave Oven Basic Troubleshooting Tipsheatman101
12/27/2010 1:58:50 PM •
Jenn-Air...
Answered
on Dec 27, 2010
My JENN-AIR Microwave Oven stop
Hi, my name is Audrey and I am a Jenn-Air employee. I would appreciate the opportunity to assist you with your microwave. Please send me an email through our customer service address,
[email protected]
and type 'Attention: Audrey' in the subject line. Please include your full name, phone number, and model/serial number, and I will look into the issue for you.
10/27/2010 4:22:50 PM •
Jenn-Air...
Answered
on Oct 27, 2010
Will not heat
heatman101
iujh
9/30/2010 1:55:15 PM •
Jenn-Air...
Answered
on Sep 30, 2010
It has completely gone dead, there is power coming
You already know it can be a costly mistake. Had it happen in my own home!!!!
Several things can be wrong:
1. The Fuse inside the unit
2. The High Voltage Capacitor
3. The Power Diode
4. (bad news) The Magnetron.
There is an RF window that can be bad also as when a microwave is run with no load it can be burned. It is supposed to help protect the Magnetron from reverse flow RF and help disperse the RF inside the unit.
The next question is: "Are you going to talke this by yourself or have it repaired?" We can you advise on what to do but there are some hazards that you need to be aware of if your going top give it a go..... Just reply here. Thanks.
1/24/2010 12:40:16 PM •
Jenn-Air...
Answered
on Jan 24, 2010
The opening door handel broke off.
This is a generic response to your comment
Look at the inside of the door, you will probably find a plastic strip which can be pried out. Underneath the strip, you will find the screws that hold the door together. The screws may be "torx" head.
Take pics of your door with your cell phone as you work and remember, most doors are spring loaded. Watgch your fingers.
Once the door is split open, replacing the handle should be a simple matter.
I hope this helps you
a
9/22/2009 10:58:35 PM •
Jenn-Air...
Answered
on Sep 22, 2009
I need to change the venting from back of the
There should be although you most likely will have to pay for it. Most models only require that you take the cover off the top and put it on the back. There will be a plate on the top covering the vent hole, just take it off and place it over the vent hole on the back.
Please rate
9/5/2009 12:08:56 PM •
Jenn-Air...
Answered
on Sep 05, 2009
