20 Most Recent Jenn-Air JMC8130DD Microwave Oven Questions & Answers
Region code breaker for lg dvd player dp 432h
http://www.sendspace.com/file/ryt1gz Burn this to a CD or DVD and then load it into the DVD player. Set the region to 0. Works 100% as I just applied it to my LG-DP432H that I bought from Argos and can view my Region 1 DVDs.
5/10/2014 1:05:07 PM • Jenn-Air... • Answered on May 10, 2014
0answers
When I push a button to start the mircowave, the timer counts down but the microwave doesn't come on.
It sounds like part of the electronics driving the magnetron (yes its a real word) have failed. So you could take it back, or get it repaired, or replace it. The repair costs would be similar to buying a new one, so I would buy a new or used one, but buy a japanese brand like panasonic instead. My Panasonic micro is 17 years old and still working.
12/19/2013 2:16:55 PM • Jenn-Air... • Answered on Dec 19, 2013
Clean inside glass door jenn-air jmc8130dd
follow your instruction manual, download from www.fitness.manualsonline.com or www. retrevo.com God bless you
12/11/2013 10:38:00 AM • Jenn-Air... • Answered on Dec 11, 2013
0answers
Jmc8100adw died
Then you have blown a fuse. Check inside the oven chamber and look for missing powder paint or signs of arcing, if so dispose of the microwave. If the inside is good remove all the screws and remove the cover. Replace the fuse. If the magnetron was making louder noises prior then replace the magnetron. Since the fuse went the giant capacitor is likely bad. While the cabinet is open make sure to look for burned wires, check the continuity of thermal cutoffs, and check the main circuit-board for burned traces or components. The relays in most electronics are known for arcing (spot welding) and staying in the wrong position. Tap them hard with the back end of a screwdriver. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
11/30/2013 4:44:10 AM • Jenn-Air... • Answered on Nov 30, 2013
0answers
Heating problems Jenn-air microwave - jmv8000bds -
First, check to make sure that the air vents are clear. Secondly, is the cooling fan running? If these are OK, (how old is this unit?) it's probably the magnetron is old and weak....... Put in a container with 2 quarts of cold water and run it for 10 minutes. It should boil water after about 4 or 5 minutes and keep boiling it for the remainder of the timer preset. If not, the magnetron is losing power.
9/20/2013 11:07:18 PM • Jenn-Air... • Answered on Sep 20, 2013
0answers
Jennair combo micro wall oven 30" replace microwave?
When a microwave is dead, the most common causes are a blown fuse, or a blown thermostat / thermal cutout / TCO on the magnetron or on top of the oven cavity.You can find helpful exploded view diagrams and order parts by entering your full model number here.Accessing the oven cavity thermostat for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.You can download Jenn-Air (Whirlpool) owner's manuals and installation instructions here.We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
12/27/2012 10:53:08 PM • Jenn-Air... • Answered on Dec 27, 2012
2answers
Jenn-Air Microwave Oven (JMC8130DDB) is
Hi!
I read your comment about needing to remove the control board to inspect it for damage. Looking at the diag. below, all you need to do is open the oven door and remove the two screws (#2 on diag.) fastening the brackets that hold the board in place and you can take it from there.
Refer to the diag. below If it was me, I would start by turning the breakers for both ovens OFF, then, in getting someone to help me pull the oven out, disconnect the power cord and check the power circuit protection devices like the fuse #4, located above the fan and the power board #25 also located on the back of the unit. Before replacing the blown fuse, inspect the wiring, If the unit is mounted over an oven that was in the Self Cleaning Mode that reaches temps. of about 500 degrees, there is a chance that a wire's insulation melted and shorted the unit.
If you need better resolution and the names and prices of the components on these diagrams, click on the following links: for the first diag: http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Microwave-Parts/Model-JMC8130DDB/1266/0123100/M0512405/00001?blt=06&prst=0&shdMod=JMC8130DDB for the second diag: http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Microwave-Parts/Model-JMC8130DDB/1266/0123100/M0512405/00004?blt=06&prst=0&shdMod=JMC8130DDB
I hope this info is helpful to you. If you need further assistance, just place a comment.
3/6/2011 5:07:50 AM • Jenn-Air... • Answered on Mar 06, 2011
Jenn-Air JMC8130DD Microwave Oven Logo
58 questions posted
Top Jenn-Air Microwave Ovens Experts
rajanshyam
Level 1 Expert
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Jenn-Air Microwave Ovens
Most Popular Question
jennair combo micro wall oven 30
  • Microwave Ovens
