20 Most Recent Maytag 26 cu. ft. Wide-By-Side Refrigerator - 36" - Stainless Steel Questions & Answers
Water dispenser and ice maker not working properly.
If the water flowed normally for a few years and now will not fill the ice maker with enough water to make full size cubes or dispenser fill too slow the problem may be a defective=> 67005154 Water Inlet Valve In the tutorial above I want you to listen carefully of all the possible items that can cause slow waterflow. I am here should you have questions Thanks Sea Breeze
5/25/2013 2:53:07 PM • Maytag 26 cu.... • Answered on May 25, 2013
Part number for back panel
get the model number off the machine itself and go to www.partselct.com and you'll be able to pull up a illustrated diagram with that company and manufacturer part number as well If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
6/22/2012 11:10:39 PM • Maytag 26 cu.... • Answered on Jun 22, 2012
MY Maytag Wide by Side freezes in the produce drawers.
When a unit freezes in the lower drawers this is usually due to a thermistor which is not functioning properly. If you can provide your model number I can try to locate your schematic to your unit showing the thermistor that you would replace to alleviate this issue. I will await your reply as to the complete model number of your unit.p.s if you had ice up the top of the unit as well then you would look at the damper door otherwise known as the diffuser door in some units or the control for the door as the problem area in your unit. Thank you, Rick
12/15/2011 8:37:19 AM • Maytag 26 cu.... • Answered on Dec 15, 2011
Maytage psd 262 not working at all
The clicking noise would be the start relay/overload. Pull the unit out away from the wall unplug the machine. Remove the rear panel on the side of the compressor is a black box remove the black box disconnect the relay and overload and replace. Walla working machine again. If you have any further questions message me back.Thank you Rick
12/13/2011 5:43:30 AM • Maytag 26 cu.... • Answered on Dec 13, 2011
Replaced water filter but can't get red light
Hello there and welcome to fixya This is a rather easy fix please try this Maytag and Jenn-Air - press and hold the lock and light buttons (lock and water on newer fridges) on the dispenser for about 4 seconds, until the indicator light blinks.
10/5/2011 12:31:58 PM • Maytag 26 cu.... • Answered on Oct 05, 2011
The refrigerator and freezer stopped cooling
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
7/28/2011 7:46:25 PM • Maytag 26 cu.... • Answered on Jul 28, 2011
Ice maker does not make ice
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
10/25/2010 4:17:22 AM • Maytag 26 cu.... • Answered on Oct 25, 2010
Ice cubes are hollow.
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
heatman101
4/27/2010 1:25:44 PM • Maytag 26 cu.... • Answered on Apr 27, 2010
Noise from inside top fan?cycles like fan touching
Usually when this happens it is because of a problem with the fan that moves cold air from the freezer section of your unit to the refrigerator section. Either the fan has gone bad or the unit has frosted up to the point of stopping the fan. Try defrosting (unplugging) the unit over night and then check it to see if the fan runs. If not then replace the fan. If it runs and then stops after awhile like days or even a few weeks, then you may need a defrost timer.
The other thing that can cause this is the heating element going bad, but this is not usually the problem. The element can be checked with an OHM meter. If the coil does not have any resistance then it is bad.
You can find parts for your unit by doing a search for “appliance parts”.
Once you get the results of the search, pick a site and when it comes up it will usually ask for the model number of your unit.
Enter your model number and you will then get a page with exploded views and a parts menu.
Find the part you need and then order it.
Check a few different sites to be sure that you are getting the best pricing.
Most sites can have the part to you in a couple of days.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
12/9/2009 3:55:35 AM • Maytag 26 cu.... • Answered on Dec 09, 2009
My freezer is fine but fridge side is warm and no air blowing
SOUNDS LIKE THE FAN FROM THE FREEZER TO THE FRIDGE TAKE OFF THE COVER TO SEE IF ITS WORKING
9/2/2009 5:52:44 PM • Maytag 26 cu.... • Answered on Sep 02, 2009
2answers
Not cooling compressor kicks on for 5 sec then
you have either a weak overfload safety witch or a bad start assist relay
8/11/2009 1:22:30 AM • Maytag 26 cu.... • Answered on Aug 11, 2009
How do you install maytag "mbb1954g" ice maker plastic water line connection to the freezer?
To connect the water supply using a plastic hose kit to the MBB1954G UNIT, you can follow these steps: Turn off the water supply valve under the sink. Remove the old hose from the water supply valve and the back of the refrigerator. Attach the new plastic hose to the water supply valve and the back of the refrigerator. Make sure the hose is not kinked or twisted. Tighten the fittings with an adjustable wrench. Turn on the water supply valve and check for leaks. Here is a video tutorial that demonstrates how to install a water line to an ice maker or refrigerator using a 5 foot hose with 1/4 inch compression fittings. INSTALLING ICE MAKER / REFRIGERATOR WATER LINE - using 1/4" compression hose (youtube.com)
2/15/2024 9:40:38 PM • Maytag... • Answered on Feb 15, 2024
Maytag 2 door fridge has only water for ice cubes. Is there a water filter for the ice?
you can add water filter. It is installed on supply line. go to Home Depot and pick up a refrigerator water filter kit with accessories.
10/19/2023 1:58:54 PM • Maytag... • Answered on Oct 19, 2023
I got some ice from the doors ice and water dispenser I heard the ice maker turn over then instead of water going into the ice maker to refill it began coming out the door water dispenser.
inspect the ice make to check for any sign of visible damage or misalignment, .and unplug the fridge and plug it again
8/23/2023 5:17:05 PM • Maytag... • Answered on Aug 23, 2023
Where is the defrost timer on Maytag top freezer RTD21E0CDL
Matthew...you sure you have the Model# right? Cuz Google comes up with Zip..Zilch with that #.? :)
8/15/2023 5:37:38 PM • Maytag... • Answered on Aug 15, 2023
My Maytag MZD2768GE frezzer side is forming ice on the bottom. Water is coming out of the lower vent.
Fridge/freezer freezing up- and no fan or air circulation: first check the defrost terminator thermostat it may have gone out. Thus not allowing the heating element to melt the ice. AT TIMES The fan usually stops working AND CAN MAKE FUNNY NOISES AS WELL due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature. May also need to check the defrost timer, The defrost timer is usually found behind the front grill "toe kick" of the refrigerator. Or in the fridge compartment near middle top section. u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad? Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next. Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance.. Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS . Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit? ALSO CHECK THE AIR FLOW VENT SYSTEM and THERMISTORS At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area! THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 1300 ( give or take 150 ohms) ohms is required Freezer /fridge leaking water/ice frozen in fridge and or freezer, or leaks on floor Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out. Fix any gaps in the door seal.Pack out the seal underneath the areas where the door seal has the gaps. This can be done with a small strip of weather stripping, as shown here, or a bit of tightly rolled up paper under the door seal. Alternatively, you can heat the door seal up with a hair dryer to fix the gaps. This softens the door seal and allows you to stretch it. Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor. However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick. Another trick one can use is to connect a copper tube wire with one end going into the drain hole then attach the other end to the heater wrap it around heater a few times. That will take care of the drain problem when it comes to ice build up but not food build up. Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also. Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer. God is so good: so this is why I give free advice so please thank him not me. OTHER THINGS TO CHECK ARE THE DEFROST TERMINATOR AND THE HEATER ELEMENT FOR COBNTINUITY. defrost timer location defrost terminator-undefined-undefined-0_2.jpg door seals cracked-fridge-seals-undefined-undefined-1.jpg drain center drain holer-undefined-undefined-2.jpg drain hole freezer downside-undefined-undefined-3.jpg evaporator-fan-blade.1280x600-undefined-undefined-4_0.jpg
7/26/2023 8:07:17 PM • Maytag... • Answered on Jul 26, 2023
Does the Maytag Model: MSD2651KES have a drip pan underneath?
The Maytag Model MSD2651KES is a side-by-side refrigerator. It does not have a traditional drip pan underneath like some other refrigerator models. Instead, it uses a drain system to collect and channel condensation and defrost water. The condensation and defrost water from the freezer section of the refrigerator typically flow down through a drain hole and into a drain pan or trough located at the bottom of the refrigerator. This drain pan is usually not accessible from the outside and does not require regular maintenance or emptying. If you are experiencing any issues with water leakage or pooling around your Maytag refrigerator, it is recommended to check the drain system for any blockages or clogs. Ensure that the drain hole is clear and that the water can flow freely through the system. If you suspect a problem with the drain system, it is advisable to consult the refrigerator's user manual or contact Maytag customer support for specific guidance on troubleshooting and resolving the issue.
6/28/2023 2:44:00 AM • Maytag... • Answered on Jun 28, 2023
Oil coming from the inside of my Maytag refrigerator door?
Either the compressor is broken or is now compromised.The compressor needs to now be replaced for your fridge.
5/10/2023 7:12:14 AM • Maytag... • Answered on May 10, 2023
Maytag  26 cu. ft. Wide-By-Side Refrigerator - 36" - Stainless Steel Logo
19 questions posted
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Refrigerators
Most Popular Question
part number back panel
  • Refrigerators
