20 Most Recent
AMD Athlon , 750 MHz Processor Questions & Answers
Hangs at PCI device listing
Go to the bios settings and reset it to Optimize Default and reboot the system after saving the settings. To go to the settings, follow the onscreen instructions of your manufacturer's direction (maybe Delete or F2 or F1). You also need to scan your system with an updated antivirus and make sure that you haven't installed two antivirus. If possible restore your system to the previous date when it was working fine. do let me know again if you can't follow all these. good luck..
Can't boot 2nd OS system from partitioned HD.
go to add and remove software, deleted the last update from Microsoft.
it should put you back to dual boot.
try to install the update manually one at a time. find the one that prevent you from dual boot and discard the update. you should be OK w/o ceratin updates.
Dual Booting
Yo u cant dual boot without restarting the machine unless you use virtualization technology ie virtual pc or vm ware
Regards Al
PCI cards don't function
as been have ssen in picture and specs of your mainboard you have a integratd vga vard and a agp slot. so solution may be this
with old integrated vga open bios program go to disply and choose pci input first. this enable you to boot from pci slot with a new vga save setting switch of computer put on new pci vga and try.
if no option to activate pci init first , sorry you can not boot any vga from pci , but only from agp slot.
Where do I start computer upgrade
Your machine is very short of power required for win 10, I would like to see at least 8 GB ram, and a faster processor, yours is at the bottom of tests. Perhaps you should look at a new machine with win 10 installed. You cannot upgrade xp to win 10. You will have to purchase a win 10 license, you missed the free upgrade period.
