20 Most Recent Hoshizaki Cubelet Ice MakerDispenser Water Cooled LED Sensor Operation Questions & Answers
Ice maker seems to have no power
sounds like a control card problem blown on board fuse
1/24/2016 3:32:43 AM • Hoshizaki... • Answered on Jan 24, 2016
2answers
I need to obtain DCM-240BAF Hoshizaki ice machine
10/9/2015 1:11:37 AM • Hoshizaki... • Answered on Oct 09, 2015
Why does it start to make ice then shut off in 15 to 30 seconds?
Thermister probably isnt getting resistance with a normal functioning unit so as a safety it turns unit off... hoshi???? Any beeps???
7/28/2015 12:44:09 AM • Hoshizaki... • Answered on Jul 28, 2015
Hoshizaki KM-450MAB Ice Machine
maybe not. it could be that the heating cycle is taking a lot of time to remove the ice from the evaporator that is why the electronics is shutting off the compressor as a protection. check the heating cycle if it is working fine. check the evaporator for dirt that would hold the ice slab from falling down quickly. check the level of the unit. it may have move and now its out of level. the unit must be leveled with the ground.
7/5/2015 12:07:00 AM • Hoshizaki... • Answered on Jul 05, 2015
Hi. My Hoshisaki ice maker Model KM-30A serial
I see this is from 2009. Has this issue been resolved? if not, I will be happy to try and help you out.
8/14/2014 3:02:05 AM • Hoshizaki... • Answered on Aug 14, 2014
Km 280 mwf stop making ice just make cold water
look for stuck water valve, reservoir leaking water causing short freeze cycles. start there and let me know if I can be of any further help.
8/14/2014 2:55:24 AM • Hoshizaki... • Answered on Aug 14, 2014
I have a Hoshizaki and the bin is very hot
can you give me some more details? not real sure what you are trying to ask?
8/14/2014 2:53:39 AM • Hoshizaki... • Answered on Aug 14, 2014
Noise water pump
I have been told that the water pumps can be rebuilt but I have always just replaced them. when they go bad, they get real loud. It is my personal preference as the time it takes to rebuild in the service industry is not cost effective.
8/14/2014 2:52:52 AM • Hoshizaki... • Answered on Aug 14, 2014
I need instructions on cleaning a Hoshizake ice maker
go to: http://www.hoshizakiamerica.com/. Click on "Support". fill in the model of your unit then click "get manual" and you are there.
8/14/2014 2:46:42 AM • Hoshizaki... • Answered on Aug 14, 2014
WHERE IS THE TEMP GAUGE ON THE ICE MACHINE HOZINAKI KM500-MAE
I am not aware of any temperature gage. what exactly are you looking for?
8/14/2014 2:44:37 AM • Hoshizaki... • Answered on Aug 14, 2014
Hoshizaki ice machine is not making ice
need more details. does it have power? is it making any noise? model and serial numbers are usually a good place to start to get help. thanks and let me know
8/14/2014 2:26:52 AM • Hoshizaki... • Answered on Aug 14, 2014
Our ice machine hoshizaki kml450mah i start of control switch to ice,1minute fill cycle water keep running not stoping until harvest cycle 3.5minute its causing to water leak all over the halway of th
look for stuck water valve. one quick way to check is to turn machine off and see if water is still running. start with that and let me know.
8/14/2014 2:01:10 AM • Hoshizaki... • Answered on Aug 14, 2014
1 minute fill cycle,harvest cycle 3.5minutes water still filling the reservoir and down to a pan drain by the time reach the freeze cycle water seem to be in normal flow but the damage its been done b
look for a stuck or otherwise malfunctioning water fill valve. one way to check, turn the machine off and see if the water is still running to fill it. start with that and let me know.
8/14/2014 1:59:57 AM • Hoshizaki... • Answered on Aug 14, 2014
Its a 450 mah hoshizaki, it keeps jumping from freeze cycle to harvest cycle without giving it enough time to make a load of ice
usually, if it does not stay in the freeze cycle long enough to make ice or it just makes slivers of ice, it is loosing water. during the freeze cycle, look to see if water is draining down the drain from the machine. If not, I would look at the float position. it should be almost completely in the lower, down position. give that a shot.
8/14/2014 1:54:42 AM • Hoshizaki... • Answered on Aug 14, 2014
Hoshizaki model AM50BAE not dropping ice...
Replace water float and check water inlet valve. with water constantly filling sump tray it will not make ice water will never cool down to 32 deg.
7/11/2014 8:30:27 PM • Hoshizaki... • Answered on Jul 11, 2014
The water intake is too long. It takes in about 6 gallons of water every cycle.
sounds like dump valve is stuck some what open
7/8/2014 6:38:38 PM • Hoshizaki... • Answered on Jul 08, 2014
Km 450 mab cycles out of freeze cycle every 5
look for some reason that the sump is loosing water. Sometimes particals get caught in the dump valve and keep it from seating. Also, the sump may not be filling all the way and it will make small cubes. Set float to it's lowest level and see if that may help
9/28/2012 3:54:32 AM • Hoshizaki... • Answered on Sep 28, 2012
Have a hoshizaki kml250mwh... pumps
If you get ice in the auger the part that makes the ice. Is a bad barring. If fan turn of and there no ice in the auger then is a bad relly on the board .you should have a reset bottom on the board. .
7/27/2011 2:57:10 PM • Hoshizaki... • Answered on Jul 27, 2011
3answers
Hoshizaki ice machine model 150 doesn't turn
  • This bin includes a proximity switch and actuator paddle assembly. The mechanical bin control assembly mounts in the ice drop zone area and will shut the unit down within 3 seconds when ice pushes the actuator paddle to the full right position, away from the proximity switch. Shut down will only occur during the first 5 minutes of the freeze cycle when the paddle is moved away from the proximity switch. If the paddle is moved away from the proximity switch and held at any other time during the sequence, the unit will continue to run until the next freeze cycle occurs. This feature allows for a full batch of ice every cycle so that there are no small cubes in the bin.
  • The bin is in the back and must be pushed all the way to the side (see diagram) You can also read more about this on page 30 of the manual I have provided (below)
Regards, Tony
5/28/2011 9:59:23 PM • Hoshizaki... • Answered on May 28, 2011
Hoshizaki Cubelet Ice MakerDispenser Water Cooled LED Sensor Operation Logo
Popular Tags
40 questions posted
Top Hoshizaki Kitchen Appliances - Others Experts
Kolbrun...
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Are you a Hoshizaki Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Hoshizaki Kitchen Appliances - Others
Most Popular Question
hoshizaki kml250mwh pumps
  • Kitchen Appliances - Others
