· The OSD Lock Out Message
Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
· 2
Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
· 3
Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
· 4
Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
· 5
The OSD Settings Menu Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series. Please leave rating if it helps.
ViewSonic Computers & Internet • Uploaded on Aug 15, 2013
132 questions posted
131 Questions
123 Questions
121 Questions
112 Questions
121 Questions
