20 Most Recent
ViewSonic E70fb 17" CRT Monitor Questions & Answers
I have one pro view
buttons are not working perfect.therefore pressing automatically. you have to remove the panel after power on the monitor, (it may be dangers therefore get support by electronic technician , he will remove buttons and solder new ones or replace the switch panel.
ViewSonic E70fB Brightness & Contrast problem
Sounds like the buttons or the button panel are messed up. Or it has gotten moisture in it.
The only time i have seen this was when one of the buttons were malfunctioning, and we ended up replacing the monitor.
I am having viewsonic E70fB
In most cases this could happen because of electronic components getting aged. I suspect the monitor's LOT or some capacitors about to die. Get them replaced with the help of a expert technician. That should fix this problem.
How to display setting
There should be a menu button on the front of this screen, in this menu you will be able to adjust the settings for your monitor, brightness, contrast, size etc...
If you would like to adjust the resolution; right click on the desktop and select Properties.
Select the settings tab and slide the resolution bar to the right to increase the resolution or to the left to decrease the resolution.
damnor01
Hi what is the model number for an e70fb
ViewSonic E70fb 17" CRT Monitor, it is not LCD flat panel monitor, it does not have backlight assemblies. It uses picture tube (CRT).
Are you asking about ViewSonic E70fb 17" CRT Monitor problem or other model?
Brightness pop-up window on screen for a long long time
There are a few things that could be wrong; someone could have a remote and be messing you about, a button could be stuck on the monitor so its increasing, the computer could be slow or signals might be getting mixed up. try and figure it out based on what ive said. good-luck!
The setting is programmed into the memory of the monitor. It has been set that way, sort of like a memory button for your car's driver seat. The car remembers your favorite seat position, and the monitor is remembering your favorite brightness settings.
It's been a while since I played with any settings on a CRT monitor, but I'm sure if you give it a few minutes, you will find in the menu how to set up the memory recall feature on your monitor.
good luck.
tony
At the centre of my viewsonic monitor model:E70fB
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This might unlock your OSD menu and remove that message from your screen. regards
I am using view sonic monitor & i am facing a
OSD and Power Lock Settings
• OSD Lock: Press and hold [1] and the up arrow for 10 seconds. If any buttons are
pressed the message OSD Locked will display for 5 seconds.
• OSD Unlock: Press and hold [1] and the up arrow again for 10 seconds.
• Power Button Lock: Press and hold [1] and the down arrow for 10 seconds. If the
power button is pressed the message Power Button Locked will display for 5 seconds. With
or without this setting, after a power failure, your LCD display’s power will automatically
turn ON when power is restored.
• Power Button Unlock: Press and hold [1] and the down arrow again for 10 seconds.
Well this Should resolve ur issue
Message blinking at the centre of monitor
OSD Unlock : Press and hold the [1] and [▼] buttons again for 5 seconds. The message “OSD UNLOCK” will then display briefly, indicating that the
OSD image settings are now unlocked.
You will find that and other information in the manual located
here. The above information is found on page 7.
Hope this helps. Please remember to rate this information.
Thanks
