20 Most Recent
Troy-Bilt 32cc 4-Cycle Gas Backpack Blower TB4BP EC Questions & Answers
TB4BP won't pull
crankcase could be full of fuel causing it to hydro lock take plug out and see if it will pull over be carefull though if it's hydro locked with fuel it will pump out of the sparkplug hole. the rope may be off of the starting pully as well
Troy-bilt TB6042 Xp oil leaking into in air filter
The typical reason to lose oil into the filer box, is that the engine has been tipped up, this allows engine oil to travel down the breather tube and into the back of the box, the other reasons are, engine worn, or the engine breather itself is faulty.
How do you adjust the drive belt on a Troy-bilt 12AV565Q711 self propelled lawn mower?
1. Disconnect the spark plug wire at the front of the mower, siphon any excess fuel from the gas tank and verify that the oil dipstick is securely fastened to avoid oil leakage.
2. Remove the screw located on the side of the mower deck, next to the right rear tire, then tilt the mower onto its side so the air filter is facing up.
3. Unfasten the blade retention bolt. The blade retention bolt is located in the center of the blade. Slide the blade off the mower.
4 Unfasten and remove the screws holding the engine baffle to the mower deck, then remove the baffle. The baffle is the circular piece located beneath the blade.
5. Remove the screw fastening the belt cover to the mower deck. Remove the spring between the belt cover and transmission pulley, then remove the belt cover to expose the belt.
6. Adjust the belt to the desired tension by manipulating the engine and transmission pulleys. If the belt has become slack due to age, you need to replace it. To remove it, slide it off the engine pulley first, then slide it off the transmission pulley.
7. Replace the removed items in reverse order.
