20 Most Recent
Coleman Powermate Pressure Washers Turbo Nozzle With Wand 2400 Psi And Questions & Answers
Coleman PM0435001
When you cleaned the carb did you clean the fuel jet that is in the carb. Quite often it is the screw that holds the fuel cup on the carb. If that little hole has any dirt in it the engine will not start or run.
Adjust water pump pressure
pressure control valves are non adjustable
They operate to unload the pump when the trigger is released
What can vary pressure is the jet size at the end of the wand
The screw and nut on the valve is only to regulate the stop/start pressure as the trigger is pressed/ released
low pressure at the wand jet can be from low water supply to the pump or pump internal problems
I cant pull the starter cord on mt coleman ct200u
Remove cover over starter pulley.
Cord wraps around this.
When cord is pulled, centrifugal force swings spring-loaded weights out, to engage the starter gear.
Check that weights are releasing when not pulled.
And that cord is still on pulley.
May have wound off the side.
