20 Most Recent
Breville BOV800XL The Smart Oven Questions & Answers
A roach got inside the LCD screen of my Breville
I had same problem. No way to get to inside of LCD screen to get roach out. Took a foil gum wrapper, slid through slots on side of oven by LCD screen. Was able to move roach out of view. Hope this helps.
Breville toaster oven - beeping and Code E05
According to sources, breville toaster oven E05 LCD error is non-resettable issue. You should immediately turn off your toaster oven and remove the power plug. After doing so, call breville customer care. Hope it helps!
What does error code E01 mean on a Breville toaster oven and how do I get it fixed?
An E01 error is not usually an error that you can fix. First, unplug the toaster oven for 30 minutes. If the error recurs, then the oven's control detected an internal fault. If the toaster oven is under warranty (one year), contact Breville Consumer Services at (866-)273-8455 or
[email protected] . If the toaster oven is not under warranty, it's probably better to replace the toaster oven. The cost of shipping and the minimum repair diagnostic fees are probably more than a new toaster oven.
I hope this helps.
What does error code E01 mean on a breville toaster oven and how to fix it?
E01 error message on my Breville Smart oven (about 3 years old.) I searched the web for info and have come up w/very little--the manual just says it has to be handled by Breville and doesn't give any more info either. Has anyone encountered this? Something I saw online indicated it might be a fatal error message..
