20 Most Recent
Memorex (32025535) DVD-R Storage Media Questions & Answers
I bought blank DVD-R at
all dvd should be blank if you are buying some with data on them that is not correct and should be brought to the attention of the store staff.
i hope this was helpful.
12/12/2010 11:23:36 PM •
Memorex...
Answered
on Dec 12, 2010
That is not a dvd
Sounds like the laser that reads DVD is not working, but the one that reads
CD is. Try swapping the drive with a known working one in another computer.
If the drive does not work in the other computer, and the other drive works in
your computer; then it looks like you need a new drive.
10/1/2010 9:10:25 PM •
Memorex...
Answered
on Oct 01, 2010
Memorex DVD-R Storage will not load on my
make sure you don't have just a cd drive. I'm assuming you have a dvd drive. Next it probably won't load if it isn't formatted. If you have files on the dvd-r that wouldn't be the problem.
11/27/2009 11:54:19 PM •
Memorex...
Answered
on Nov 27, 2009
When I am going to install windows xp give
Try Step 1 & Step 2. If you are not able to perform recovery console, then follow Step 3 & Step 4.
Step 1. http://www.articlesbase.com/data-recovery-articles/could-not-install-windows-xp-due-to-hard-drive-damage-1244273.html
Step 2. http://ezinearticles.com/?Could-Not-Install-Windows-XP-Due-to-Hard-Drive-Damage&id=2944653
Step 3. http://support.microsoft.com/kb/314058
Step 4. http://support.microsoft.com/kb/307654
Hope it works for you.
Warm regards,
Anirban Mazumdar
10/16/2009 9:07:49 AM •
Memorex...
Answered
on Oct 16, 2009
Why does 700mb disc formatted to only have 552mb?
at the command prompt type chkdsk X: /f /r where X is pen drive.If it doesn't work download the recovery tool here http://freeware-fix.blogspot.com/2013/04/usb-drive-is-unreadable.htm
12/20/2013 7:42:20 PM •
Memorex...
Answered
on Dec 20, 2013
How do i format a write protected cd
If it is write-protected, then it is a CD-R or DVD-writable that has been written on -- once written, you cannot "format" it, nor "erase" any files.
Such is the "design" of "write-once" disks.
If it is a CD-RW or a DVD-RW, then you can "erase" the disk, because it has been designed to be "rewritable".
11/11/2009 7:54:09 PM •
Memorex...
Answered
on Nov 11, 2009
Yeah i bought a 50pack DVD+R 16x 4.7GB 120min. and
bluee_eyes --
Been there...
I'm sure you have tried, but have you cleaned your optics lately?
Using a Q-tip and a small amount of rubbing alcohol, and GENTLY rotate the swab across the lens, rotating it in the opposite direction you are wiping. This should "lift" any dust or grime from the lens. I would also clean the tray with a soft lint-free cloth (using an air-can just moves the dirt around, doesn't solve the problem)
Hope this helps!
-- RT
PS - Don't forget to vote!
10/1/2009 7:55:37 PM •
Memorex...
Answered
on Oct 01, 2009
Travel Drive Broke
It depends on your skill level as to if it can be fixed or not. The data is most likely still safely stored on the flash chip inside the drive casing. However, the USB connector has been just ripped off. If you have any experience soldering it would be as simple as getting a replacement usb plug from an electronics store or cutting a cable you have and then soldering the USB connector back to the flash drive inside the casing. This is something than can be done at home or possible by a repair shop that does any type of soldering work(tv, radios, ect) Most computer repair shops will look at you silly if you ask them to solder a thumb drive back to life. I would not expect more than to be able to mount your drive and copy the data. Odds are after you cut it out of the casing it will never go back in correctly.
Good Luck
8/21/2009 1:02:06 AM •
Memorex...
Answered
on Aug 21, 2009
CAN'T SEEM TO GET VHS TO RECORD
You inset a blank tape.
Tune the VCR to the channel or input source you desire to record.
Press the "REC" or "RECORD" button on the front panel or remote control. Everything should work out ok.
If you still have problems getting a source to your VCR, check the input cables and/or channel automatic programming freatures on the VCR.
1/23/2009 1:14:37 AM •
Memorex...
Answered
on Jan 23, 2009
