20 Most Recent
Jenn-Air Jenn Air D156, D156B Replacement Oven Temperature Sensor Kit Questions & Answers
WATER LEAKS UNDER THE SINK WHEN DISHWASHER IS IN
Check the connection to the drain tailpiece from the dishwasher under the sink and make sure the clamp hasn't slipped off and is tight. Check the drain hose from the dishwasher and be sure it's not split or damaged. Check the drain spur on the drain tailpiece and see if it's corroded or leaking. Check the trap under the sink as well and make sure it's not leaking.
10/17/2017 8:44:12 PM •
Jenn-Air...
Answered
on Oct 17, 2017
Jenn air quiet series II
Couple of things to check: there's a float that needs to more freely, make sure it does. There's dishwasher cleaning instructions in the operation manual. You may need to take the lower rack out, take off the spray arm to get at a filter, which you should clean and replace. Then you can try to run some white vinegar through a wash cycle. Jean Air has these instruction at their web site.
2/1/2016 5:52:22 PM •
Jenn-Air...
Answered
on Feb 01, 2016
