20 Most Recent Jenn-Air 24 in. JDB8910 Built-in Dishwasher Questions & Answers
Our Kleenmaid DW39X dishwasher is
http://kleenmaid-appliances.com/dishwashers-care-kleenmaid.aspx
http://kleenmaid-appliances.com/Use&Care/DW/KM_DW/DW39X_U&C.pdf
user manual. above, above that is the Kleenmaid web site.
Kleenmaid has a 10 year warranty, PARTS & LABOR ! so in my professional opinion, you shouldn't repair it yourself, you simply need to call them and make an appointment for a FREE parts & labor. Of course, IF it is OVER 10 years old, then maybe you may wish to try.
http://www.kleenmaid.com.au/guarantees.asp
have a look, copy/paste at that link above, it is the guarantee site.
http://forum.appliancepartspros.com/sitemap/f-3.html
http://www.repairclinic.com/Dishwasher-Repair-Help
I have also included the below "Fix" this may or may NOT have anything to do with your problem however, you would be amazed just how many problems are sorted, with the doing of the "Remedy"...
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You shouldNEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
7/29/2013 1:50:33 PM • Jenn-Air 24 in.... • Answered on Jul 29, 2013
2answers
Will not complete wash cycle
I had the same problem. It tried to start every few seconds when draining. I made sure there was nothing jammed in the motor, it was clean. I checked the resistance of the two windings and they were about the same. I thought it was the relay on the board but after changing it there was no improvement. I connected power directly to the motor and it just hummed. I then realized it was probably the starter capacitor. I swapped the wires between the drain and washing windings and started the motor in the diagnostic mode and it ran. While looking at the starter caps on the board I realized one was loose. I re-soldered both starter caps and it works fine.
9/26/2011 11:44:17 PM • Jenn-Air 24 in.... • Answered on Sep 26, 2011
3answers
Hi i have a jenn-air dishwasher JDB8910AWW about
I have a Jenn air dishwasher JDB8910AWW It fills with water but will not wash also i hear a clicking sound and the control panel blinks
3/30/2011 8:57:00 PM • Jenn-Air 24 in.... • Answered on Mar 30, 2011
I have a Jenn aire
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
2/27/2011 11:01:10 PM • Jenn-Air 24 in.... • Answered on Feb 27, 2011
2answers
My Jenn Air Quiet Series
Here is a link that will help narrow it down http://appliancehelponline.com/dishnopowervideo.html
9/10/2010 1:49:58 PM • Jenn-Air 24 in.... • Answered on Sep 10, 2010
My jdb1250awr has an odor
Select a short wash cycle and start the machine. As soon as it fills with water and starts washing,open the door and add 1 cup of white vinegar.
Then resume the wash cycle.
When that cycle finishes repeat the process EXCEPT this time add 1/2 cup bleach.
7/5/2010 7:32:43 PM • Jenn-Air 24 in.... • Answered on Jul 05, 2010
I recently replaced the control on a Jenn air
Hi
Thanks for using FixYa. From what you have described it seems to be a issue with the control panel that has gone bad and needs to be replaced. You can buy a new one from this link. Please doaccept the solution if the issue is resolved or else revert for furtherassistance.
Thanks
Rylee
4/13/2010 3:12:58 PM • Jenn-Air 24 in.... • Answered on Apr 13, 2010
Will not drain or resume a cycle makes a clicking
Programme sounds faulty - could be pricey to get fixed.
2/16/2010 9:45:04 PM • Jenn-Air 24 in.... • Answered on Feb 16, 2010
I get absolutely nothing... no flashing lights
Check the breaker in the breaker box and see if its tripped
12/31/2009 2:06:29 PM • Jenn-Air 24 in.... • Answered on Dec 31, 2009
Where can I obtain another cutlery basket for a
9 Moselle Avenue
Lincoln 0610, Auckland, New Zealand
+64 9 835 9025
10/6/2009 12:18:17 AM • Jenn-Air 24 in.... • Answered on Oct 06, 2009
I have a Jenn-Air dishwasher, model JDB8910AWS.
Turn off source power, then black to black, white to white and ground to green, is the typical connection.
9/18/2009 8:43:58 PM • Jenn-Air 24 in.... • Answered on Sep 18, 2009
2answers
Jenn air jdb8910 does nothing
Had a similar problem with mine a few weeks ago. It was intermittent in not working on delay. My first thought was that the close switch was not working. Upon disassembling the door, and fiddling with the switch, I heard some sizzling on one of the circuit boards. A little more digging revealed some cold solder joints on a couple of board mounted relays.
I removed the board, re-soldered the loose relays, and everything has worked fine since.
9/5/2009 1:40:30 PM • Jenn-Air 24 in.... • Answered on Sep 05, 2009
Not enough water to wash dishes and machine keeps filling
The " inlet valve" as you call it is very cheap $20.00 at right store! easy fix
3/16/2009 11:52:49 PM • Jenn-Air 24 in.... • Answered on Mar 16, 2009
Jenn-Air JDB8910 dishwasher moisture coming out left side.
thats a vent fan to help with drying cycle its normal for steam to come out during cycle of drying you might use no heat air dry and turn your jet dry disp up but its a normal part of drying cycle
2/11/2009 11:49:37 PM • Jenn-Air 24 in.... • Answered on Feb 11, 2009
Door spring on dishwasher broke
I have just done this on my own dishwasher, and managed to bend the next curl of the springs to replace the broken ends, see instructions and pictures here:-
http://www.howtofixanything.co.uk/howto-260.html
1/15/2009 1:36:39 AM • Jenn-Air 24 in.... • Answered on Jan 15, 2009
Jenn-Air 24 in. JDB8910 Built-in Dishwasher Logo
49 questions posted
Top Jenn-Air Dishwashers Experts
Mike Cairns
Mike Cairns
Renee Knafel-Bullock
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Jenn-Air Dishwashers
Most Popular Question
jenn air dishwasher jdb8910aww about
  • Dishwashers
