20 Most Recent
Panasonic CF E1 PC Desktop Questions & Answers
Keyboard and Mouse
Try pricewatch.com.....if it exists you can probably find it there. But..is it essential you have a square one? The only determining factor for a keyboard or mouse is the connection....that ranges from wireless (in which case you must also have a receiver), to usb to serial. Look at the end of your keyboard and mouse and match it..they have pictures. By the way I recently bought several mice and keyboards on sale at Gearxs.com.....paid $2.44 and $3.68. They were new and logitech and worked. Tango.
Panasonic CF-E1 Bios Update
Thats an old pc and flashing the bios (if not done right) could kill your pc..... with it bein so old and computers now being so cheap your best bet is to invest in a new computer. I have looked for your bios update with no luck either.
Drivers For Panasonic CF E1
You will need to find out what motherboard/graphics are in your pc, then search for drivers,
but as this is no longer made or supported and everthing is built in the unit, it's more than likely of retirement age
Panasonic cf-19 Enter key not working
- Fn is locked (pressed-down) until you press another key. Use this when pressing difficult key combinations. • Popup menu icon on/off Start up the Hotkey Settings. Click [start] - [All Programs] - [Panasonic] - [Hotkey Settings]. Make the settings. [Use Fn key lock] When using an Fn key combination Press Fn once.
6/16/2023 9:14:01 AM •
Panasonic...
Answered
on Jun 16, 2023
My Panasonic TV model no: TH-32D310Q Green light is blinking
A blinking green light on your Panasonic TH-32D310Q TV typically indicates an issue with the TV's power supply. Here are a few steps you can try to resolve the issue:
Unplug the TV from the power outlet and wait for at least 5 minutes. Then, plug it back in and see if the green light stops blinking.
Check the power cord and make sure it is securely plugged into both the TV and the power outlet. If the cord is loose, try tightening it or using a different power outlet.
Check the TV's manual or website to see if there are any troubleshooting steps you can take to resolve the issue.
If none of these steps work, it may be a more serious issue with the TV's power supply or internal components. In this case, you may need to contact Panasonic South Africa for assistance or bring the TV to a professional repair shop.
4/1/2023 6:12:39 PM •
Panasonic...
Answered
on Apr 01, 2023
