20 Most Recent
Panasonic Workio DP-2330 Printer Questions & Answers
Panasonic Workio Dp 2500 problem
change any one of the IP adress to one group..i.e.,change 192.168.2.20(address of Printer) to 192.168.1 to 99 or the the other way round..that would solve your problem...
2330 drum repair
Drums are cheap. Replace it along with cleaning blade cleaning roller and charge roller. Perform F8-14 and F8-20.
I kan't enter service mode panasonic 2330
Press the FUNCTION/ORIGINAL SIZE (ledger)/3 buttons in that order, and hold the buttons until all are depressed..Press and hold FUNCTION....then press and hold ORIGINAL SIZE (ledger)....then press and hold 3. The service screen will open with F(x) at top middle of screen.
Error e401
This is a fuser warm up error. First check the thermistor if it is dirty clean it, check lamp & thermal fuse. Changing the thermistor &/or thermal fuse usually fixes this issue!
Key counter missing
Machine is looking for Key Counter. You need to go into the Service Mmode and turn off.All 3 of these need to be held down at the same time:Press and hold FunctionPress Original Size (Ledger)Press the #3This will put you in the Functin Service ModePress the #5 the Startscroll to around # 42 (Dept-Key Counter) PressSelect No or turn offAfter done press Stop-clearThen press and hold Fuction and Clear to get out of Service Mode
