20 Most Recent
Panasonic WORKiO DP-C262 Printer Questions & Answers
How do i Reset U29
In the manual it will tell you how to reset the drum counter on Page 190 (DP-C265 manual). Reset all the different counters and that will likely clear the problem. A lot of sites want you to buy new drums at $170 a crack. I have reset mine 3 times already and still have perfect printing over 100,000 copies later.
Printer is asking to replace drum unit cyan
open the front door, remove the waste container & replace the drum with a UHN30 color drum then reinsert the waste container & close front door...machine will cycle & adjust itself
Replace drum unit cyan
open the front door, remove the waste container & replace the cyan drum with a new UHN30 color drum (these drums work for all the colors on this)
Panasonic kx-mb2030 check drum error
You need to remove and reinsert the drum cartridge. Instructions on how to reinsert the drum cartridge can be found on page 10 of the operating instructions found at http://shop.panasonic.com/resources/content/UCM_STG_CNT_039795.pdf
Panasonic KX-MB263 - CHECK DRUM- error
The drum unit must be nearing the end. You will need to replace it soon. Check the page count and check for howmany pages the drum is rated for. If the pagecount has reached the rated count, then its ok, if you are far from the rated limit, you will have to check with the supplier for possible refund.
