20 Most Recent
Whirlpool Stove / Oven / Range Cooktop - 4455568 Questions & Answers
Fame to low on my whirlpool stove
You mean the flame is low. You need to clean the burner jet hole orifice and also check if their is a gas pressure regulator which you can adjust the pressure a lithe more higher.
The burners pop whenever the gas is on
You didn't mention if it only pops when you first turn them on or that the popping is continuous.
If it when you first turn them on, then I would suspect late ignition. Too much gas build-up before ignition takes place. The spark gap may need to be adjusted or the spark module replaced.
If it happens continuously there may be a short in one of the switches or wiring harness.
6/1/2014 7:06:30 PM •
Whirlpool...
Answered
on Jun 01, 2014
