20 Most Recent
LG Electronics LD451EGL 45-Pint Dehumidifier - Humidifiers & Questions & Answers
What does error code CH 24 mean?
The CH67 code is generally related to either a fan motor failure or a blockage to the air inflow. It is recommended to check the filter, and make sure that none of the vents are obstructed. If this does not resolve the matter, then the unit may require service. To make service arrangements, you may either contact our Customer Interactive Center at
800-243-0000, or you can check our Repair Provider Lookup on our website, at
http://www.lg.com/us/support/repair....
LG LD450EAL no power
Try resetting the GFI breaker, assuming it is connected to one. Also check the main breaker panel to make sure the breaker is not tripped. Unfortunately the electronic panels do go bad in these systems after a few years of service. Try resetting the unit. There should be a tiny reset button on the back. Also if the bucket is full it will not turn on, make sure it is in place and seated properly or it will not turn on. There may be a reset on the cord itself as well, hope this helps.
