20 Most Recent Coleman Mobile Modular Home Electric Furnace Eb12 Eb12c Questions & Answers
Auto fan does not start electric furnace
see this causes and fix it. God bless youIf the furnace won't run, check the electrical service panel for a blown fuse or tripped breaker. Also make sure the power switch on or near the furnace is turned on. Check the unit for a reset button and try it. Some units have a built-in breaker or fuse panel. If there is not enough heat, raise the thermostat setting five degrees to see if it turns the unit on. If the unit still does not generate enough heat, check the comfort controls . Clean or replace a dirty filter, clean the blower assembly (see the Forced-Air Distribution Fix-It Guide), and make sure that all registers are open and not blocked. If the furnace turns on and off repeatedly (cycles), clean or replace the filter; and clean the blower assembly (see Forced-Air Distribution Fix-It Guide). If the furnace is noisy, make sure access panels are mounted and fastened securely; spray squeaking belts with fan-belt dressing and replace worn or damaged belts; adjust the blower belt; lubricate motor and blower oil ports. If the element does not heat, refer to the Heating Element Fix-It Guide for guidance.
11/18/2013 6:22:55 PM • Coleman Mobile... • Answered on Nov 18, 2013
I need wiring diagram for coleman evcon model#
Yrs
3/24/2024 6:06:20 PM • Coleman Heating... • Answered on Mar 24, 2024
I have a Coleman Evcon DGAT070BDE furnace issue with kicking on and blowing cool air when my thermostat is turned Off.
4 flashes is ahigh limt switch open or a 24 volt fuse open . Which could be afaulty blower or a blocked air filter .
3/14/2024 11:52:07 PM • Coleman Heating... • Answered on Mar 14, 2024
Coleman Heatpump Condenser Model TH4B4822SA
possible freon low
12/8/2023 8:47:18 AM • Coleman Heating... • Answered on Dec 08, 2023
Coleman 024-27651-000 blower motor common wire
This website 024-27651-000 Blower Motor - Mobile Home Repair says the color codes as Red-low, yellow-medium low, blue-medium high, black-high, green-ground, orange & brown to capacitor
9/21/2023 1:37:41 PM • Coleman Heating... • Answered on Sep 21, 2023
2answers
How do I wire a Coleman Evcon 3500A916 furnace Model
Wiring Diagram for a Coleman Furnace - RV-Coach Online
www.rv-coach.com > Discussion Forum > RV - Insurance
... Furnace, Mark, 9-12-07. Need wiring diagram for coleman furnace Model # 7700B856 .... Amanda, 11-10-11. I need a wiring diagram for a Coleman evconpresidential model 7956c856 ... Need wireing diagram for coleman 3500a916 ... More results from www.rv-coach.com
FURNACE Diagram & Parts List for Model eb15b Coleman ...
7/5/2023 9:09:04 AM • Coleman Heating... • Answered on Jul 05, 2023
2answers
Coleman Chillgrille model 9330A633. Where does the air filter go please?
behind the grill assembly https://docplayer.net/58906974-Installation-instructions-for-9330a633-chillgrille-flush-mount-ceiling-assembly-infrared-remote-control-system.html
6/24/2023 7:32:06 AM • Coleman Heating... • Answered on Jun 24, 2023
2021 Coleman Mach AC Unit not turning on...
Based on the symptoms you described for your Coleman Mach 10 NDQ Air Conditioner, it appears that there may be an issue with the compressor or the electrical system. Here are a few suggestions for further troubleshooting:
  1. Check for proper power supply: Ensure that the air conditioner is receiving the correct voltage and that the power source is stable. Fluctuations or insufficient power supply can cause the buzzing sound and cycling of the thermal overload relay. If you're experiencing issues specifically when running on generator power, it's possible that the generator is not providing consistent or adequate power for the air conditioner's operation.
  2. Inspect compressor and electrical connections: Check the compressor and all electrical connections to ensure they are clean, tight, and free from corrosion. Loose or damaged connections can result in poor electrical flow and contribute to the buzzing sound and cycling of the thermal overload relay.
  3. Consult a professional technician: Given that you have already replaced the start capacitor, run capacitor, and installed a soft-start kit without resolving the issue, it might be best to consult a professional HVAC technician who specializes in air conditioner repairs. They will have the expertise and tools necessary to diagnose and address the specific problem with your unit.
  4. Contact Coleman Support: Reach out to Coleman's customer support for guidance and assistance. Provide them with all the details of the issue, including the model number, symptoms, and the steps you have already taken for troubleshooting. They may be able to provide further insights or recommend authorized service centers in your area.
Remember to prioritize safety and always follow proper procedures when working with electrical systems or seeking professional assistance for repairs.
6/16/2023 8:58:12 PM • Coleman Heating... • Answered on Jun 16, 2023
3answers
My Coleman furnace won't blow unless I manually put the blower switch to on
If it is a propane or gas furnace you need a gas registered technician to diagnose and fix. The likely problem is in the control board.
5/18/2023 12:17:31 PM • Coleman Heating... • Answered on May 18, 2023
Coleman Evcon mg9s060b12mp11a fan speed blower slowest setup?
who ever designed and installed your system probably using wrong sizing for duct work and never balanced the air flow-- also should be able to adjust but keep in mind system design need certain air flow over coils so will probably need to redesign the plenum --trunk --and vents
5/12/2023 12:18:36 PM • Coleman Heating... • Answered on May 12, 2023
I need a sequencer for a Coleman Presidential 2 furnace air conditioner
It is gas appliance, it can only be repaired by a certified gas engineer. And worse, it is in a mobile home!https://www.google.com/search?q=coleman+presidential+2+furnace+replacement+parts..
4/16/2023 3:44:33 PM • Coleman Heating... • Answered on Apr 16, 2023
2answers
Do you know where I
You need to contact Coleman and ask the user guide.
Click here to contact Coleman.
3/18/2023 11:31:40 PM • Coleman Heating... • Answered on Mar 18, 2023
Coleman Presidential II Furnace: No heat and blower motor is running constantly.
This could be due to either an open safety switch such as a rollout or high limit, or the relay could be welded inside the control board constantly sending 120 volts to the blower motor. A less common cause could be a bad thermostat which can be verified by removing the face plate. If the blower stops, then the thermostat will need to be replaced.
2/3/2023 3:20:13 AM • Coleman Heating... • Answered on Feb 03, 2023
Coleman Furnace error codes 3 green light blinks pilot light comes on but it don't egnite
I found the following utube video, which seems close to your issue. Hope this helps: https://www.youtube.com/watch?v=h3OzVDpUGM4&ab_channel=TalentedMen
1/24/2023 3:19:35 PM • Coleman Heating... • Answered on Jan 24, 2023
Coleman furnace 29 red flashes
Coleman flash codes. It may be 10 flashes twice. https://www.google.com/search?q=Coleman+furnace+29+red+flashes ..
1/3/2023 10:16:45 PM • Coleman Heating... • Answered on Jan 03, 2023
Coleman Mobile Modular Home Electric Furnace Eb12 Eb12c Logo
Popular Tags
3 questions posted
Top Coleman Heating & Cooling Experts
Paul Carew
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Coleman Heating & Cooling
Most Popular Question
auto fan not start electric furnace
  • Heating & Cooling
