20 Most Recent Zanussi TC7102W Electric Dryer Questions & Answers
4answers
Making an electrical noise, but drum not turning. Sounds like it's shorting.
I'd suggest - remove the top cover. Switch on. Push the drum around - see if the drum picks up speed and continues to run. If this happens, it means that the motor Starter capacitor has gone dud and will need replacing. Note- If the drum doesn't continue to rotate after you shove it, switch off immediately. It will likely then be a faulty motor.
8/16/2018 11:14:51 PM • Zanussi TC7102W... • Answered on Aug 16, 2018
0answers
Zanussi TC7102W, water leak near front right, have replaced ALL
Perhaps the tank itself is cracked?
1/10/2018 2:47:27 PM • Zanussi TC7102W... • Answered on Jan 10, 2018
My lg td-c70045e dryer causes a power surge throughout the whole
Dryer more than likely draws more current than other light duty appliances that are plugged in.
11/4/2017 1:30:53 AM • Zanussi TC7102W... • Answered on Nov 04, 2017
0answers
Squeak
Be the first to answer 6/29/2017 3:30:04 AM • Zanussi TC7102W... • Posted on Jun 29, 2017Be the first to answer
3answers
Dryer does not dry clothes
If the dryer tumbles but does not warm up, you either have one or two blown thermal fuses, a burned out element if it’s electric, or a burned out igniter if it’s gas.
If one of the two thermal fuses are blown you will not get heat.  Thermal fuses blow (and are not resetable, they must be replaced) when the machine gets too hot.  Often this is caused by not enough air flow through the machine.  Check and make sure your exhaust vent is not clogged.  Clean it the best you can to get all the lint, dead mice, bird nests, etc. out.  Also make sure air is blowing out of the machine when it is turned on.  If not you have a blower problem.
The thermal fuses are located on the element casing.  They each have two wires coming out of them.  They are about 3/4 inch round with screw ears on the sides so they are about 1 1/2 inch long and about an inch across.  With a multimeter, check the continuity across the terminals.  If there is no continuity the fuse needs to be replaced.
To check the element(s), you can either visually look and see if it is broken or check the continuity with a multimeter.  No continuity means the element is broken.  Replace if necessary.
To check for a broken igniter, take out the old one and look at it.  If it looks broken or very burned, replace it.
1/9/2017 10:44:14 AM • Zanussi TC7102W... • Answered on Jan 09, 2017
It is taking far too long to dry, this has only recently started? what could be the problem?
Dryer Taking Too Long To Dry Clothes - GE Appliances
products.geappliances.com/appliance/gea-support-search-content?...
To minimize the possibility of electric shock, unplug the dryer from the power supply ... When clothes are taking a long time to dry or do not seem to be drying, the ...Missing: zanussi ‎tc7102w ‎far
Dryer Troubleshooting: Takes Too Long to Dry - YouTube
? 2:13 https://www.youtube.com/watch?v=ql6_fRRc20c Dec 14, 2009 - Uploaded by ManageMyLife Here are common reasons why laundry can take longer to dry than normal. ... my dryer takes too long to dry. i have cleaned it, hose, lint screen, could this has anything to do with ... Dryer Troubleshooting - Not Drying or Taking a Long Time to Dry - Duration: 14:08. ... How Does an Electric Dryer Work?Missing: zanussi ‎tc7102w ‎far
Dryer Troubleshooting - Not Drying or Taking a Long Time ...
? 14:08 https://www.youtube.com/watch?v=xiqlFX0VRQo Jun 26, 2012 - Uploaded by Bill Newberry Why is my Dryer taking too long to dry. How to .... What type of connector shoul
1/21/2016 12:16:02 AM • Zanussi TC7102W... • Answered on Jan 21, 2016
Tripping electricity think it might be the bearing is worn
Hi , if its tripping electricty you must have a shorting wire either some water drop is leaking onto a live wire. The unit will have to be checked .
1/13/2016 1:07:06 PM • Zanussi TC7102W... • Answered on Jan 13, 2016
How to repair a zanussi condenser tumble dryer belt
Access from the rear panel to drive belt: - Remove the worktop - Remove the side panels - Remove the rear panel cover - Remove the rear panel - Remove the motor unit Dado
10/21/2015 9:31:05 PM • Zanussi TC7102W... • Answered on Oct 21, 2015
2answers
Zanussi Condenser Tumble Dryer
go to the zanussi web site you should be able to download a manual good luck
3/11/2015 8:23:07 AM • Zanussi TC7102W... • Answered on Mar 11, 2015
START BUTTON SWITCH REPLACEMENT FOR DRYER ZDE
-Why replace it...? Broken...? If so replace it. Good Luck mai
11/14/2014 8:35:42 PM • Zanussi TC7102W... • Answered on Nov 14, 2014
My dryer is just blowin cold air but its still spins can you help try and solve what the matter with it
Hi, the same thing happened to me and is quite an easy fix, 1 remove the plug from the wall socket. 2 Inside of the drum at 12 o clock (above the door on the inside) is a thermal cut out which has tripped due to overheating. 3 Remove two screws on the retaining clip and take the thermal cutout out. This should be self resetting but for some reason it has not reset (a continuity test with a multi-meter will prove this is the problem) 4 Give it a sharp tap on the bench and it will re-set ( if this sounds too extreme go out and buy a new one but trust me it will work)
6/25/2014 6:44:17 AM • Zanussi TC7102W... • Answered on Jun 25, 2014
0answers
How to clean inside the holes below the door
Try a hoover tube taped over the end so that there is only a small hole remaining. This gives extra suction. Liz
4/13/2014 8:35:59 AM • Zanussi TC7102W... • Answered on Apr 13, 2014
Zanussi TC7102W Electric Dryer Logo
187 questions posted
Top Zanussi Dryers Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
View Most Popular
Zanussi Dryers
  • Zanussi Dryers
Most Popular Question
dryer just blowin cold air but its still
  • Dryers
