20 Most Recent
Zanussi TC7114W Electric Dryer Questions & Answers
Zanussi zdc46130w Fault.
I think you should read the instruction manual . 3 beeps means some information to begin a solutin.
How do i fix my dryer
Check and see if the motor is turning when you start it up. If it does then you have a broken drive belt which is common with any dryer.
Zanussi dryer tc
Did you locate the "tensioner" wheel that may have jumped out of the mounting hole...??
There are two wheels, one on the motor and one on the tensioner...
Condensation belching out on to floor
Hi, I suggest that you check that all the lint has been removed from the dryer, especially the condenser cabinet area.
Check that the rubber seals around the condenser unit have not been damaged, or dislodged - especially on the inner part of the small door.
Also check that the plates in the condenser unit have not been damaged as this could also be the cause of the leak.
If the two red stops cannot be turned to hold the condenser unit in place, the condenser unit is not installed properly, so carefully remove it, check there are no obstructions where the unit goes, and try to slide it back into place so the red stops can secure the unit in place.
If you have no success after doing this, you may have to get the unit serviced.
Full water indicator lit continuously even though
Problem was a stuck float in the small water reservoir to the rear left of the unit.. Remove top and left hand side panel. Small reservoir can be seen at the bottom left. Remove small screw and slide off the cable assembly above. You should then see into the reservoir and the float. Clean float and reservoir and reassemble.
The heat is there but it doesnt dry the clothes
You have one of 2 problems. Your clothes are getting put into the machine too wet because the washer isn't spinning them out all the way. Or you have a clogged vent causing the unit to take too long to dry properly because it can't remove the moisture properly. Check your vent outside to see how hard the dryer is blowing the air.
