20 Most Recent
Baumatic B484SS Stainless Steel Electric Single Oven Questions & Answers
My Baumatic B484SS oven started
Switch off the mains then examine the cable to main switch to see if there is a loose connection.These ovens are usually on the 30 amp fuse.If that looks okay ...you may have an internal wire than is touching the chassis...most internal wires are shielded with heat resistant material ...it may be that one has melted or burnt through and is now shorting on the metal chassis.Look for evidence of burnt areas.finally check the switches...these get oil and water ingress which again will short out the circuit and trip the main board.hope this gives you a starting point and solution.
BAUMATIC OVENS BO7C wiring schematics
the fastest way to get access to the manual would be to call the company and ask them to email it to you. Then you can print it out on your end if you wish.
Thank you.
